Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-16-2008, 08:58 AM
emgee's Avatar
emgee is starting off with a positive reputation.
Unhappy Noisy front end
I've got a couple of noises coming from the front end of my '80 F100 (300 I6, shortbox). The first is a high pitched yelp or chirp...very sudden when I hit a small bump or small pothole. The second noise I'm getting is a ticking noise usually when I'm turning right at slow (parking lot) speeds. The truck has new king pins, coils, tie rods and shocks. The steering box is older but not original. Also, the truck seems to want to stray to the right slightly not long after a wheel alignment). Any help is appreciated.
  #2 (permalink)
Old 05-16-2008, 01:57 PM
81-F-150-Explorer is gaining momentum as a positive member of FTE.81-F-150-Explorer is gaining momentum as a positive member of FTE.
Quote:
Possible Cause is the radius arm, or axle bushings being slightly worn.
This could be caused by a wheel bearing. Inspect and repack wheel bearings, replace if a problem is discovered. It could also be the brake shoe clicking on the rotor. Make sure the brake anti rattle clips are present, and/or the brake shoe is snug in the caliper. Not rattling around etc.
The slight wander to the right can be because of the crown in the road. The road isn't completely flat, it's sloped toward the ditches with the center line being the highest point. This is so water will drain off the road. Therefore nothing you can do about it. If it doesn't show signs of wear on the tires due to a misalignment, then you are ok.
hope this helps.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
