Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-16-2008, 07:35 AM
1970460 is starting off with a positive reputation.
Hello new and Questions
Hi I am new here, I am thinking about buying a 1970 Lincoln 460, but I need to know what the cam profile is and what measurements the pistons are so I can get forged. Thanks in advance.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-16-2008, 09:38 AM
Question
I tried registering at 460.com but that was like 2 weeks ago and this seems like another good place to get the answers I seek. I am looking to keep the engine fairly stock other than a port and polish, aluminum intake and a different carb and better ignition system, ohh and a windage tray, but I would like to know the original cam specs like duration and lobe and lift so I can fine something after market that is very similar, And I would like the pistons to be forged or at least hypereticute (I know I can't spell lol). Thanks for any help you may be able to give. Anyone know what the connecting rod length is on this motor? again its a 1970 lincoln 460. thanks guys
  #3 (permalink)
Old 05-16-2008, 12:17 PM
Bear 45/70's Avatar
Bear 45/70 is gaining momentum as a positive member of FTE.Bear 45/70 is gaining momentum as a positive member of FTE.
The engine is just a standard 460 of that era. Rated at 365 horsepower @ 4600 and 500 ft/lbs of torque @ 2800 and the compression was 10.5 to 1.
The rods are 6.605" c to c.
The cam is 256° intake and 270° exhaust with 36° overlap and .278" lift on the lobe and .487" at the valve.
The bore is 4.36" but can't help you with the piston profile other than they are dished and the pin is offset 0.625".
__________________
Bear 45/70
Gimp Racing
Don't pick a fight with an old man. If he is too old to fight he will just kill you.
  #4 (permalink)
Old 05-16-2008, 04:36 PM
Thanks very much. This motor says on the car its in its rated at 385 horsepower and it says it needs premium. Does this make a difference? as far as the cam profile goes? And does anyone know where I could find some forged pistons that would fit at? summit racing says all they can get is cast. Thanks again very much for the help. sorry forgot to ask something is the .487 the lift at the exhaust and what is the lift at the intake? is it .278? sorry for all the questions thanks for the help.
  #5 (permalink)
Old 05-16-2008, 04:46 PM
Bear 45/70's Avatar
They played a bunch of games with horsepower ratings back then and they all need premium fuel with a 10.5 to 1 compression. Are you sure it says 385 as even the CJ or Boss 429 weren't rated that high. Can't help you with forgings as I don't rev my 460 motor past 5000 rpm (usually only 4000 to 4500 max) and forged is not required for that.
__________________
Bear 45/70
Gimp Racing
  #6 (permalink)
Old 05-17-2008, 07:14 AM
yeah has a little badge on the old lincoln on the front radiator mount that says what size motor and the rating for the engine. So the correct cam profile would be 256 degrees intake and 270 degrees exhaust with but still can't find any cams with that many degrees and only .478 lift on the exhaust? are the lift measurements at 50 or at 36? thanks again
  #7 (permalink)
Old 05-17-2008, 11:06 AM
Bear 45/70's Avatar
The cam specs are from back when (early 1970s) everything in cam specs was gross, from baseline to max lift.
__________________
Bear 45/70
Gimp Racing
  #8 (permalink)
Old 05-17-2008, 06:42 PM
so what does gross mean? And what modern alternative would be best? thanks
  #9 (permalink)
Old 05-17-2008, 06:50 PM
Bear 45/70's Avatar
Gross means from baseline to max lift was measued, not starting a .050" of lift.
__________________
Bear 45/70
Gimp Racing
  #10 (permalink)
Old 05-17-2008, 07:54 PM
Ahhhh I think I understand. So what would the old specs be at .50 so I can find a newer cam shaft? thanks sorry I'm not understanding this. My old 460 was much easier it was a 1977 out of an LTD, since it had emission style heads the build was easy, no need to try and match the original.
  #11 (permalink)
Old 05-18-2008, 09:35 AM
velcro7279 is starting off with a positive reputation.
1970460,
Just a thought that no one here has mentioned here yet. I think the heads have to be done with hardened seats to hold up to running unleaded fuel. Since it is a 1970 engine, and they ran leaded gas back then. Not sure if you were planning on going that far or not. Someone correct me if I am wrong here.
Steve
  #12 (permalink)
Old 05-21-2008, 07:34 AM
darrin1999 is starting off with a positive reputation.
nope youre right, it should have hardened seats put in to run pump gas. as for a cam why would you want to put a stock cam back in? there are lots of aftermarket cams that are better than the stock one... also what are you using the motor for? hyper pistons may be a better choice than forged because theyre more thermally stable so if you want an engine that will go 100k+ you may want to go hypers... but they dont take detonation at all. forged pistons will take detonation and bad tune much better than hypers but they expand and contract so much that they wear the rings out at around 75-100k miles.
__________________
drive trane parts may strand you, but suspension parts can kill you.
if you cant pay cash for it, you cant afford it.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
