Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-16-2008, 04:27 AM
superman724's Avatar
superman724 is starting off with a positive reputation.
tow/haul button
how come the 02 x dosnt come with a tow/haul button
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-16-2008, 07:05 AM
OK, OK, so I'm a
housedad is starting off with a positive reputation.
The 02 model year was not available with the Torqueshift transmission, they were all equipped with the 4R100. Only the Torqueshift equipped vehicles have a Tow/Haul button, and only the 2004/2005 Diesel models, at that.
Bion Rogers
__________________
2005 EXCURSION!! XLT V10 Silver Heated trailer mirrors, Hood/window deflector, Firestone airbags/onboard air, Helwig swaybar, Prodigy, underhood liner and light, V's and Modded B's, Bilsteins, Procomp stabilizer, Curt front reciever, 6 disk Visteon stereo, 6 disk changer console, X-3 AIC. 4.30 axles
  #3 (permalink)
Old 05-16-2008, 07:26 AM
katiesdad7 is starting off with a positive reputation.
Don't you need to have the diesel to get the Torqueshift?
__________________
2005 Eddie Bauer 4x4 w/6.0
Who said size doesn't matter?
  #4 (permalink)
Old 05-16-2008, 07:48 AM
OK, OK, so I'm a
Yes, it was only available with the Diesels.
"and only the 2004/2005 Diesel models, at that."
__________________
  #5 (permalink)
Old 05-16-2008, 07:59 AM
Sanchez_315er is starting off with a positive reputation.
Ummm... I have an 04 V10 with a tow-haul button on the shifter.
__________________
04 Excursion 4x4 EB V10 3.73s
Rockwood 8317SS Travel Trailer
  #6 (permalink)
Old 05-16-2008, 08:25 AM
OK, OK, so I'm a
I find that illuminating.
Are you sure that on the shifter it says the words "Tow/Haul", and not "Overdrive Off"? You might want to check which transmission you really have. It might be that odd vehicle you hear about sometimes.
If it says "Overdrive Off" then it is a 4r100
I just verified the books and the Ford Source Books and the Ordering Books do not show the Torqueshift transmission as a possible option for either the 2004 or 2005 year with the V-10, and these are the books the dealer uses to order them from.
If you have the Torqueshift and not the 4R100, then it is a unique animal.
Bion Rogers
__________________
  #7 (permalink)
Old 05-16-2008, 09:12 AM
Definitely a 4-speed, I wish it was the 5.
It says "overdrive off", I guess I have commonly calle dthat a "tow haul" button. My mistake.
Anyone here ever swap in a 5-speed into an X?
__________________
  #8 (permalink)
Old 05-16-2008, 09:57 AM
thanks for the answer, so whats the best way to tow with an 02 x diesel should i drive with overdrive off or on. appreciate the knowledge guys
  #9 (permalink)
Old 05-16-2008, 10:35 AM
OK, OK, so I'm a
Quote:
Since I have never had a diesel, I'l leave that answer to the diesel folks. You can also get more information about towing in general at RV.NET
Bion Rogers
__________________
  #10 (permalink)
Old 05-16-2008, 12:34 PM
islander1808's Avatar
islander1808 is starting off with a positive reputation.
I have an 03 with the Tow/Haul button. Just thought that I would chime in.
__________________
2003 Eddie Bauer 4x4 6.0L PSD Ex
4" MBRP Turbo Back w/ Cat Delete, ZooDad
Edge Juice W/ Attitude Platinum
285/75 Nitto Terragrapplers
Monroe Reflex
RAS (have it, not installed)
  #11 (permalink)
Old 05-16-2008, 12:44 PM
Monsta's Avatar
Sit. Stay. Become a
Monsta has a great reputation on FTE.Monsta has a great reputation on FTE.Monsta has a great reputation on FTE.Monsta has a great reputation on FTE.Monsta has a great reputation on FTE.
Quote:
I'm currently looking into it. It may be prohibitively expensive though. I'm looking to use the 5R110 that is in the back of the E-series with the 2V V10.
I'm also exploring the installing of a ZF-6 (manual). Wife may not be real keen on that one though. She prefers the slushbox.
I'll post when I move forward on either plan.
__________________
Ken
05V10
So many cats, so few recipes.
  #12 (permalink)
Old 05-16-2008, 09:00 PM
Mark Kovalsky's Avatar
Mark Kovalsky has a very good reputation on FTE.Mark Kovalsky has a very good reputation on FTE.Mark Kovalsky has a very good reputation on FTE.
Quote:
FYI, that trans is identical to the trans in the 3V V10 4x2 F series, and is also identical to the trans in the 6.0L 4x2 trucks.
__________________
Mark
Former Ford automatic transmission engineer, 1988-2007.
  #13 (permalink)
Old 05-17-2008, 04:41 AM
Monsta's Avatar
Sit. Stay. Become a
Interesting info! Thanks! Certainly helps with the search.
They have a separate controller that is compatible with my truck? That's why I considered one from an existing 2V powerplant in case I had to swap PCM. I could always add a custom tune so that I wouldn't have my truck "de-powered" running the PCM from the E-series.
__________________
Ken
05V10
  #14 (permalink)
Old 05-17-2008, 10:34 AM
weekendwarriorfsw32's Avatar
PSD ALL THE WAY
weekendwarriorfsw32 has a good reputation on FTE.weekendwarriorfsw32 has a good reputation on FTE.weekendwarriorfsw32 has a good reputation on FTE.
It depends on how much weight your towing. Me personaly I tow 9,500 with out on and its fine but then again I dont know how much your towing.
__________________
-Nick
Worlds Youngest Power Stroker
PAA#9
04 X 6.0
08 mirrors, 2 1/2 inch trailer hitch receiver, Fire stone air bags
01 X 7.3
6637 air filter mod, 05 head lights, MBRP 4 inch Exhaust, Running boardlights, Cab lights, Dipricol Gauges Boost, Pryo, Trans, Dp tuner 80E, 60 Decel, 80t, 140s, HI, Powerslot rotors and Hawk LTS Pads, OBA, WW
  #15 (permalink)
Old 05-17-2008, 02:52 PM
im towing two jet skis so say less then 5000lbs
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
