Hello all,
I was wondering about my 04 X with the 6.0. A year ago it could easily get an average of 15 and now babying it, it only gets 12. Any way to Gain any MPG weather it be Exhaust or Intake or Tuning. BTW This truck hauls a 13,000 Toy Hauler if that has anything to do with it,
Thanks
Nick
__________________
-Nick
Worlds Youngest Power Stroker
PAA#9
04 X 6.0
08 mirrors, 2 1/2 inch trailer hitch receiver, Fire stone air bags
01 X 7.3
6637 air filter mod, 05 head lights, MBRP 4 inch Exhaust, Running boardlights, Cab lights, Dipricol Gauges Boost, Pryo, Trans, Dp tuner 80E, 60 Decel, 80t, 140s, HI, Powerslot rotors and Hawk LTS Pads, OBA, WW
Your sig. looks like you've done the exhaust and intake or at least filter which I don't think improves anything. (Personal opinion) I would not go the tuner route unless you are out of warranty or don't mind entertaining the thought of headstuds in the future. Since the time frame you are speaking about involves the switch over to ULSD fuel, I would consider that as a possibile contributing factor. If you haven't tried a cetane booster, I would give that a try. It would be the cheapest and easiest thing to try first.
__________________
"05 F-250, CC, LB, 3.73, Lariet, with coolant filter and Bilstein shocks, S. Ca.
"69 Mustang, Mach 1, 428 CJ, Ram Air, Stock
"71 Triumph Trident
2007 Thor Jazz 5er, 11k, 31'
I believe that portion of the sig is talking about his 7.3
exhaust and tuner would help
everyone will recommend the sct from spartan diesel but I'm pretty sure that the edge with attitude gets the best mpg against the other tuners
I never take mine off of level 1 (economy) which is something like 40hp and 60ft/lb's so I'm not worried about heads/trannys and I get 20 mpg city /24 hwy/ less than 12 with just about any thing more than 8k pounds behind me
__________________
-03 F250 FX4 Lariat Crew Cab, 6.0, Edge with attitude, turboback 4" MBRP with 8" tip, AFE CAI, 6" Fabtech lift, 35" Nitto Terra Grapplers, 18x12.5" Weld Cheyenne wheels, Autometer Pro-Comp Boost and Pyro, Westin Bull Bar, B&W Gooseneck Hitch
-35' Load Pro Flatbed Gooseneck
-17' Bass Tracker Pro17
Doesn't matter where you run it if you value a warranty you are rolling the dice.
Very true =D. I guess its debatable though. I'm personally out of warranty but the tuners been on since about day 5 of the trucks life. Every time I needed warranty work I just took it out.
I was speaking more in general of everyone who is spooked by the edge since people have lost trannys/ lifted heads by running it at level 3,4,5
and he's got a 04 so he should be out of warranty by now
__________________
O no that is for my 01 X with the 7.3. The only things I have done to my 04 X with the 6.0 is 2 1/2 Reciver, Fire stone air bags, Helwig anti sway bar and 08 towing mirrors.
__________________
-Nick
PAA#9
04 X 6.0
01 X 7.3
I was thinking exhaust any favorites around here. Sorry for all the querstions but the 6.0 is a way diffrent beast then the 7.3 that I am used to.
__________________
-Nick
PAA#9
04 X 6.0
01 X 7.3
So you think edge is the way to go. I have always been scared about lifting the heads so thats while I am a little iffy on the tuner. But from what I read Matt @ spartin is the man but I am still up for options! And about the warranty no it still has 2 more years left My dad opted for the extened warranty
__________________
-Nick
PAA#9
04 X 6.0
01 X 7.3
