Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1997 - 2003 F150 97-03 F-150, 97-99 F250LD, 7700 & 04 F-150 Heritage
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 11:03 PM
Bushwhacker1 is starting off with a positive reputation.
Oil smoke on cold startup
My 200 F150 extended cab 4X4 with 4.6l engine & 150,000km puts out a cloud of blue smoke the first time it is started up. After that, it doesn't seem to do it on restart. It consumed a couple of litres of oil during a moose hunting trip last fall. It doesn't noticeably emit oil smoke once it is running. It seems like the oil pools somewhere and leaks into the cylinders and burns off when started cold. Is this a common problem? Valve seals???
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-16-2008, 08:24 AM
ground_zero298 is starting off with a positive reputation.
Probably just valve guides. If it's not using a god awful amount I wouldn't worry about it. My 99 sat for 2 years with out being started when I was over sea's. When I got back one of mine had gone bad. So my truck would puff alittle with 18k on it. 170k now and still runnin strong. Plug fouls out every 20-30k now. Not a big deal in my book. It's just a little oil that puddles when the truck sits for long periods, then burns off when you start it.
  #3 (permalink)
Old 05-16-2008, 09:58 AM
Spotty is starting off with a positive reputation.
Yeah, I agree valve guides, mine does it now and then on start up, I have a 98 with145,000 miles...runs like new otherwise. Has always used a quart between changes (3000 mile intervals), I have no leaks, just uses a little. I would not worry about it one bit. Just keep up with fesh oil and filter changes as you feel needed.
__________________
98 Ford F-150.4.6.4x4. Extended Cab 8' Box
97 Mustang Gt, Black on Black, 100% stock
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
