Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 10:55 PM
SchaefferUSMC is starting off with a positive reputation.
Is there a handheld code scanner for '94.5...
1994.5 7.3 PS, I went looking today at Checkers or Kragen or whatever it's called, and the one the parts guy showed me, I think on OBD 1, on the back said '94 7.3 N/A. Is there something else out there? I'd like to have one. I bought a Cam Pos Censor, and I think that's the problem, but I'd like to have one on hand anyway. The truck's while driving before it's completely warmed up, will do a real quick studder/die only for like a second or so. Anyway, thanks for any words of wisdom.
SchaefferUSMC
  #2 (permalink)
Old 05-16-2008, 05:45 AM
Cuda_jim's Avatar
BECOME A ------------>
Cuda_jim has a good reputation on FTE.Cuda_jim has a good reputation on FTE.Cuda_jim has a good reputation on FTE.
Are you getting a check engine light? Most likely a CPS though,
need more info.
Look here:
http://www.ford-trucks.com/forums/74...ml#post6159975
N/A stands for "Normally Aspirated" = non turbo. No turbo....no PSD.
It's a 93 to early 94 IDI engine.
I'm not sure but you may have both OBD1 and OBD2 connectors on your truck..my 96 does.
The OBD2 connector is under the dash in the middle of the truck,
the OBD1 connector is under the hood.
  #3 (permalink)
Old 05-16-2008, 07:17 AM
When I wrote N/A, I meant Not Applicable, not Normally Aspirated, but thanks for the post
SchaefferUSMC
  #4 (permalink)
Old 05-16-2008, 08:55 AM
superdav is starting off with a positive reputation.
I have an Snap-On Ethos scanner. It reads codes and data and has connectors for OBD1 and OBD2. Works well on domestic and asian.
Dave
  #5 (permalink)
Old 05-16-2008, 09:16 AM
Cuda_jim's Avatar
Quote:
SchaefferUSMC
You will find that most cheap scanners will not work on PSD's, I have an Auto xray that turns the engine off when you hit scan.
I do have an Autoenginuity that is a the cat's meow...but pricey. Most good scanners are expensive though.
Some Autozone scanners (brand name?) work on our trucks...most of the counter help doesn't know how to use them though. At least they will scan it for free.
Ooh Rah!
  #6 (permalink)
Old 05-16-2008, 11:17 AM
250turbo is starting off with a positive reputation.
check aeroforce scan gauge,pulls codes,buzz&contribution tests
kurt
__________________
'96 f250 h.d. p.d.s. super cab,long bed,e40d with cOOnhunterjoe trans mod.gutted ebpv,3x4 d.p. & 4" exhaust,gauges,ab injectors,tranny& inter coolers,ex. brake,ccv mod,130 gallons motion lotion,fs2500 by pass,certifed j b welder
  #7 (permalink)
Old 05-17-2008, 09:02 AM
MagKarl is starting off with a positive reputation.
I'm in the same boat as the original poster. I think I'm going to get a scan guage for it, but I will likely need to get my PCM reflashed in order to make it work with the OBD2.
__________________
1995 F350 XLT CC 4WD PSD 5 Speed
Rose 160cc Stage 1 injectors
Tymar intake
Autometer Pyro and Boost
Tymar 3-4" DP & 4" Exhaust
TW Chip
6.0L SD Intercooler
SD Captains Chairs
2001 Excursion Limited 4x4 V-10
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
