Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 10:33 PM
joestratton1 is starting off with a positive reputation.
AOD again
I have an 84 F250 351
I assume I have C-6 as it is not overdrive, I like the C-6 its tough as nails had a couple on my 70 fords when I had them. Thinking of switching to an AOD because I'm a carpenter and jobs are a long way away bout 1/2 the time. I always have about 1000#s of tools in truck, I pull a big saw or carry a heavy diesel tank maybe once every 2-3 months. Do you think an AOD is a good solution for me for mileage? what years? any computer problems? I turn 2600 rpm at 65 and 3000 rpm at 70-75. I think I have a dana 60 rearend because it has a ridge in the middle and a fill hole, don't know gear ratio.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-15-2008, 10:51 PM
85e150six4mtod has a good reputation on FTE.85e150six4mtod has a good reputation on FTE.
The AOD isn't cheap in a beefed, upgraded form. Think $2000 plus the install:
TCI Auto: AOD StreetFighterŽ Transmission 4X4
www.CKPerformance.com
Check this site, they sell parts for upgrades. '88-93 cores are mentioned, as it took Ford a looonnnnggg time to figure this trans out, if, in fact, they ever did.
AOD Transmission from PATC, AOD Transmissions
More parts, upgrades & info:
Main Tech Help Page - Baumann Electronic Controls, LLC
An alternative:
Gear Vendors under/overdrive transmissions the most awarded auxiliary transmissions.
At $4/gallon, you have to save 750 or so gallons of gas to make sense of this at all. With approx 20% OD, maybe you'll save 10%.
55 mph starts to look good.....
Time or money, maybe both. No free lunch methinks....
BTW, assume you have a 351W, the M is a diff bell and the AOD won't fit. Can't keep track of the multiple
35x engine years....
  #3 (permalink)
Old 06-08-2008, 03:52 PM
Talking
OK,
was walking around the junk yard today, minding my own business and saw a funny decal on an F150. it was a Gear Vendors underdrive/overdrive sign. i looks underneath and sure enough there it is, looks intact, i check the floorboard and the step switch is there all wiring seems intact.
SO my question is the donor truck is an 88 trans code "K" like my 84
(C-6), is there a difference in the transmissions?
the tail shaft looks a little different is it? can i swap it with my tailshaft if it is?
And i also found a 85 F250 diesel with a C-6 and a borg warner overdrive, would this be a better fit?
  #4 (permalink)
Old 06-09-2008, 02:56 PM
Contact GV direct:
I can't imagine the one you found can't be made to work with your trans. The basic unit is the same, just the way it hooks up, methinks....
As for the BW unit, have not heard of such a beast, perhaps this was adapted from '60s-'70s electric ODs found on the tails of 3 on the tree transmissions?
  #5 (permalink)
Old 06-09-2008, 05:05 PM
thanks for the link
looks like the tail shaft is part of the overdrive, thats why it looked funny. gonna go get it this weekend
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
