Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 10:17 PM
jeremiah302 is starting off with a positive reputation.
New Truck For me Possibly
Here's the deal I have run across a 1995 F-150 w/a 302 4x4 Long Bed. It belongs to a friend of mine and he is in a financial bind and is selling the truck to me for $300.00 dollars, that is a steal. He hasn't been able to drive it in a while b/c he has had problems w/the waterpump on it. He said the bolt holes have been stripped out, now if it is the same as my truck "which is a 88 w/a 302 efi" it has a housing behind the water pump that can be replaced, am I right about this? Everything else on the truck works. If any one can give me some advice about if I'm right on the water pump it would be cool.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-15-2008, 10:20 PM
Truckin4life has a good reputation on FTE.Truckin4life has a good reputation on FTE.Truckin4life has a good reputation on FTE.
I do belive you are corect on the housing... I do belive there are some bolts that go all the way through to the block though... If those are the ones stripped out then they will need to be drilled and helicoiled...
__________________
Don
: 12 volt specialist
1995 f-250 ext. cab, lb. 4x4, 5.8 5 speed. Performance mods, and a heavy foot.
Quote:
Originally Posted by STGFordCrazy04 View Post
X2 and hes not talking about truck nuts
Welcome to the Minions house.....Giving correct answers since 2007.
  #3 (permalink)
Old 05-15-2008, 10:24 PM
thats what I thought b/c when I replaced the water pump on my truck 2 weeks ago I seen the housing behind it, the bolts he is talking about are the ones that hold the water pump on though, but I know some of them go into the block itself, lucky for me I have access to a big shop and plenty of tools..lol
  #4 (permalink)
Old 05-15-2008, 11:29 PM
Dre82s is starting off with a positive reputation.
For your own sake do not use helycoil!, go ahead and tap it and re-thread it with a bigger bolt
  #5 (permalink)
Old 05-16-2008, 12:51 AM
ok now do the bolts for the water pump housing go the whole way through the block? and if so how big of a deal is it to get them out?
  #6 (permalink)
Old 05-16-2008, 05:12 PM
1966Tbird is starting off with a positive reputation.
yeah they go through the block and into the water passage, but only 4 of them do this. just drill everything out 1 size bigger and tap the hole, a helicoil will not work at all and hell for $300 i wouldnt worry about it if you trash the block you can sell parts for more than that.
  #7 (permalink)
Old 05-16-2008, 05:13 PM
and be sure to pull the timing cover in order to drill and tap everything, not that hard but while your in there you could always throw a new bump stick in her.
  #8 (permalink)
Old 05-16-2008, 06:59 PM
flareside_thunder is starting off with a positive reputation.
Yea the timing chain cover is the plate you are referring to......it's aluminum that'd be why...FYI I have a helicoil in my driver side head for an intake bolt and it works just fine..even torqued to specs.
JR
  #9 (permalink)
Old 05-16-2008, 07:22 PM
that's different a helicoil works because ti bottoms out in the bolt hole and won't turn anymore, you can't use it in a hole that goes all the way through
  #10 (permalink)
Old 05-16-2008, 07:50 PM
cool tbird thanks for the info, if I do mess anything up at least I have another 302 motor that is in my current truck that I can use or take parts off of. I am going to go get the truck tomorrow and park her at the shop so I can work on it when I get off of work, and if everything pans out and the tuck runs right it will be a daily driven truck.
  #11 (permalink)
Old 05-17-2008, 12:27 PM
I disagree...I had my helicoil done in the bolt hole on the end of my head.....it goes all the way through.........it is not the helicoil you're probly thinking of with the bent over bottom on it.......when the machine shop did mine (can't thank them enough either) they used some sort of special resin that just came out to hold it into the oversized threads they had tapped.
JR
  #12 (permalink)
Old 05-18-2008, 10:06 PM
today I went to the shop and pulled the water pump and the timing chain cover off of the block, and the were no bolts that went the whole way through the block what so ever. One thing that I WAS NOT prepared for was the fact the Harmonic Balancer had to come off before the timing chain cover did, that was a chore to get off. I examined the block and the timing chain cover's bolt holes and w/luck they do not need to be drilled and tapped. The gasket on the timing chain cover was bad thats the reason it wasn't holding water. So I decided to take the oil pan off or thought I would and discovered I have to take the exhaust off just to get the oil pan out, so tomorrow that will come off. I any one has anything they think I should do while the timing chain cover is off and the oil pan is off let me know, One of the things I am going to do is replace the small gasket in the timing chain houseing cover for sure no sense in putting it back together and it going bad
  #13 (permalink)
Old 05-19-2008, 05:44 AM
alz alz is offline
alz is starting off with a positive reputation.
If you are going to pull the oil pan, use a one piece gasket. If the pan is coming completely out, it's a good idea to replace the oil pump and pickup(and pan if it shows signs of rusting through).
__________________
1995 F150 4x4 SC 302 4R70W MAF
  #14 (permalink)
Old 05-19-2008, 04:22 PM
Not to mention a double roller timing chain..hell might as well do a cam swap too!lol
JR
  #15 (permalink)
Old 05-19-2008, 08:24 PM
The oil pan gasket is a one piece anyways, and replacing the oil pump and pick up is a good idea, ty Alz... and the idea of a cam swap not going to happen, I don't want to sink to much money into it and turn around and have the thing blow up on me or give out.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
