Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 11:05 PM
fordboy67 is starting off with a positive reputation.
Noise under passenger floor
I am in the process of trading up from my Expedition to an Excursion. I test drove a 2002 4X4 with 110,000 miles. While on city streets I can hear and feel a slight rattle that seems to be right under the passenger side floor. Is this possibly a sway bar bushing or something possibly more severe? Any help would be appreciated as I am in the negotiating process. Thanks in advance.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-16-2008, 12:10 AM
kappysworld is starting off with a positive reputation.
Could be sway bar bushing, Loose bolt on the suspension, Leaf spring rattle. Loose fuel line. Good luck finding it. I have been chasing a thunk/clunk for a few months now
__________________
__________________
2000 Ex V10 4.88's
- Class V hitch, Reese 1700 lb WD hitch
- Rear Hellwig, Ride Rite Air Suspension
- Procomp 6 inch lift, double shock front loop,
- 315*75*16 BFG AT's
2000 F350 Crew Cab 7.3
- AFE intake
- AFE Monster Exhaust
- Procomp 4 inch lift, double shock front loop,
  #3 (permalink)
Old 05-16-2008, 04:13 AM
snurtle112 is starting off with a positive reputation.
my guess endlinks...=) some might agree
  #4 (permalink)
Old 05-16-2008, 08:28 AM
katiesdad7 is starting off with a positive reputation.
I believe that the exhaust is hitting towards the rear and you hear it under the floor. I had this on my 01 Ex with the V8.
__________________
2005 Eddie Bauer 4x4 w/6.0
Who said size doesn't matter?
  #5 (permalink)
Old 05-16-2008, 10:44 AM
X_Hemi_Guy's Avatar
X_Hemi_Guy has a very good reputation on FTE.X_Hemi_Guy has a very good reputation on FTE.X_Hemi_Guy has a very good reputation on FTE.
Rattle?...could be as simple as a heat shield...
The heat shields are simply tack welded on the corners and if a weld fractures...you hear the rattle...
If you can...check the heat shields...the fix is easy...either take off the loose shield...or get a big stainless hose clamp and crank her down...that's what I've done in the past with great results...
Or...it could be more serious as suggested above.
GOOD LUCK!
joe.
__________________
2005 Ex V10 4.30's
- Hensley Arrow
- Rear Hellwig
- Prodigy
- RoadMaster Active Rear Suspension
- Bilsteins
- K&N drop in
2007 JayFlight 31BHDS (35' Hitch to Bumper)
  #6 (permalink)
Old 05-16-2008, 12:49 PM
xr7390GT is starting off with a positive reputation.
Don't forget body mount, usually on driver's side feet however. More of a clunk. This was a problem on 2000 models. If its a V10 check the heat shield as mentioned.
__________________
03 Excursion EB 4WD 7.3L, 03 Taurus SEL(daily driver), 01 Lincoln LS V8, 68 Cougar xr7GT http://www.supermotors.net/vehicles/registry/3724
  #7 (permalink)
Old 05-16-2008, 02:31 PM
eatfish's Avatar
eatfish is starting off with a positive reputation.
The running boards can rattle if they get loose. Especially over little bumps.
__________________
Fillet and Release >-))))*>
  #8 (permalink)
Old 05-18-2008, 10:22 PM
Ex'ed out's Avatar
Ex'ed out is starting off with a positive reputation.
Happened to me as well...under the passenger side...was a worn end link.
  #9 (permalink)
Old 05-23-2008, 09:30 PM
I think I finally found the noise, it is more of a squeek when beginning and ending motion cycles. I sprayed the body mount with a spray lubricant and after a few miles it got a lot better, all but eliminating the squeak. The mount is solid and tight, just squeaks. It got better after I lubricated it. Might try something a little more permanent, maybe a lithium grease lubricant spray? Any thoughts?
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
