Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 09:56 PM
DixieOffroad89 is starting off with a positive reputation.
header gasket?
Im installing headers on my 89 single cab 250, it has a 460, i was told not use the gasket they give you. what is the best choice to use?
Hedman Hedders 89466
  #2 (permalink)
Old 05-16-2008, 08:10 AM
Lazy K is starting off with a positive reputation.
If it was me I would use the gasket that comes with them.
  #3 (permalink)
Old 05-16-2008, 06:14 PM
flareside_thunder is starting off with a positive reputation.
not no but hell no...that's what i did with mine and it's blown out 3 friggin times...get aluminum header gaskets...a bit pricey but well worth it...they won't leak.
JR
  #4 (permalink)
Old 05-16-2008, 06:20 PM
BChance's Avatar
BChance is starting off with a positive reputation.
The coppers are even better..
__________________
BChance
Los Alamos, NM
JOIN NEW MEXICO CHAPTER HERE!
"Oderint Dum Metuant"
  #5 (permalink)
Old 05-16-2008, 06:22 PM
They are but the coppers eventually burn out and leak.
JR
  #6 (permalink)
Old 05-16-2008, 07:09 PM
95F350XL is starting off with a positive reputation.
The Mr Gasket Resusable Aluminum ones are the best. The ones that come with the headers are junk.
__________________
1995 F-350 XL 115K 5.8L 351
E4OD B&M Shift Kit
MSD 6A Blaster TIF Coil Taylor Wires
Flowtech LT’s True Dual Header Back
Flowmaster 40’s Dual 3.5” Tips Before Rear Tire
36x12.5x16.5 GY RT/II’s Military Issue
AR Baja 16.5x10 K&N 4.10 Limited Slip
  #7 (permalink)
Old 05-16-2008, 07:48 PM
dirty ernie is starting off with a positive reputation.
Absolutely, aluminium gaskets. I worked in a speed shop in NY for a few years. Saw a lotta guys come in for aluminum gaskets after friggen with the gaskest that come with the headers.
Also, be sure to use locktite, and retighten the bolts after a couple days. They almost always loosen after they heat up a few times. Instead of the hex head bolts that come with the headers, I always used round head bolts with the hex inside. Way easier to loosen and tighten without having to try to angle that damn box wrench in between everything.
Locktite everything. Just my opinion dude.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
