Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 09:30 PM
cheese5.0 is starting off with a positive reputation.
96 302 feels a little sluggish. sucking up my $3.95 a gallon
for about the past week or week and a half my truck( 96 f150 4x4 302 auto) has been feeling a little down on the power. feels like i have a load in the bed or i've got the ac blasted on a hot day. also the throttle response is down quite a bit and its drinking my expensive gas . i've done all the basic tune up things like plugs, wires, distributor cap, intake, fuel filter, fuel pump, and all fluids. also just changed the oil 2 days ago. i cant afford to be running around drivin it tryin to figure whats wrong with it. if any one has a hunch feel free to throw it my way, anything is appriciated. thanks
  #2 (permalink)
Old 05-15-2008, 09:46 PM
DJdemon6696 is starting off with a positive reputation.
what is the mpg that she is getting the 302 isnt a torque monster.. remember that and what gearing do you have?
  #3 (permalink)
Old 05-16-2008, 06:42 AM
it probably gets around 10 maybe a little less around town. its the 3.55 ls diff. i've had the truck for a couple years and i know she can do better. if anything i just want my throttle response back haha. i figured its probably a bad sensor or something along those lines i just wanted to ask someone with a little more experience so i dont waste any money on the wrong part
  #4 (permalink)
Old 05-16-2008, 07:00 AM
bluesman2333's Avatar
bluesman2333 is starting off with a positive reputation.
You can do a few basic things like tests and poking around. Look for vacuum leaks by using an unlit propane torch, clean the MAF, check TPS voltage and adjust if necessary, clean the IAC, replace the O2 sensors, do a compression test, check fuel pressure and pull vac line on the regulator to see if fuel is in it (replace it if it is), pull the injectors and have them ultrasonically cleaned, clean the upper intake, check the cats for being plugged, check the thermostat, check the computer for codes, check tire pressure, the list goes on. These are just a few things off the top of my head that commonly pop up that affect fuel mileage.
__________________
1993 F150 302 somesortofautomatic. F350 front springs, bed liner, tool box, ugly tail gate. One thing you can say about a F series truck is it's as aerodynamic as a brick, turned sideways.
  #5 (permalink)
Old 05-16-2008, 07:19 AM
thanks i appriciate it. i'll make sure i try most of those. also since you mentioned it, i thought instead of cleaning the cats out i would just gut them for a little better sound and flow once i get my mileage prob fixed. any adivice on this?
  #6 (permalink)
Old 05-16-2008, 07:25 AM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
Pull the codes... this is always the first step. Ford Fuel Injection has a simple DIY method for this, no special tools required.
__________________
Paul O
1990 F150 4x4 XLT Extended Cab 5.9(351 .030" over), FMS SEFI MAF Kit, Ported E6s, Crane 444232,
AOD, TransGo Shift Kit, 3:55LS, Flowtech Longtubes, TweecerRT
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08
  #7 (permalink)
Old 05-16-2008, 07:39 AM
You don't actually clean cats, if they are plugged you just replace them. Replacement high flow cats do the same thing as rodded out cats plus you get the benefit of being legal still.
__________________
  #8 (permalink)
Old 05-16-2008, 10:07 AM
quicklook2's Avatar
quicklook2 has a good reputation on FTE.quicklook2 has a good reputation on FTE.quicklook2 has a good reputation on FTE.
i think he meant 'gutting' the cats when he said cleaning.
read codes.
what brand and kind of plugs?
__________________
"The essence of knowledge is, having it, to apply it; not having it, to confess your ignorance." ~Confucius
  #9 (permalink)
Old 05-16-2008, 01:17 PM
alz alz is offline
alz is starting off with a positive reputation.
He has a 96, so it's more than likely OBDII. There are only codes if the CEL is on, right?
How's the clutch fan?
__________________
1995 F150 4x4 SC 302 4R70W MAF
  #10 (permalink)
Old 05-16-2008, 02:05 PM
quicklook2's Avatar
codes can happen without the cel on.
clutch fan is a possible problem, they usually howl.
__________________
  #11 (permalink)
Old 05-16-2008, 02:13 PM
actually that could be it. to answer quicklook i did mean gutting haha and they're accel brand plugs i got in a tune up kit with wires and a distributor cap. i know i have the obd2 but i could just take it in and have the codes read at advanced i've done it before. will that bring me the same results? and the belt squeeks like crazy after it rains or when theres moisture, is that my fan clutch?
  #12 (permalink)
Old 05-16-2008, 02:22 PM
alz alz is offline
Best to use just the motorcraft brand tune up parts.
As for codes, AutoZone or the like won't read unless the CEL is on.
__________________
  #13 (permalink)
Old 05-16-2008, 03:01 PM
quicklook2's Avatar
try motorcraft copper resistor plugs. (or autolite, before someone else says they are the same, i will.)
disconnect the serp belt and go for a quick drive and see if you have better performance.
you will not have power steering so be careful.
buy a code reader or count the blinking light.
__________________
  #14 (permalink)
Old 05-16-2008, 03:23 PM
thanks a lot guys. i'll try those ideas next chance i get
  #15 (permalink)
Old 05-22-2008, 07:08 AM
hate to bring this thread back. i'm pretty sure its not my fan clutch but i could be wrong. my fan seems to be working correctly and moves freely when the engine is cold. since i posted last there is a slight whining noise comming from the engine bay. it increases with rmps but doesnt decrease as fast. it sounds like a have a supercharger under the hood, except i have less power. i've read some previous threads and while searching for belt problems i cam across some people getting weird noises like this when their air pump? goes bad. could mine be going bad along with my belt/pulleys/fan clutch?
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
