Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 09:20 PM
donniezyea is starting off with a positive reputation.
1986 four speed granny tranny grindin
Hey everyone i got a little problem here that im sure has been disscussed but i would like to have some help again. I have a 86 f-150 with a 6 inch lift and 32's with a four speed tranny with granny but i recently lost a syncro in second gear- a real bummer. I took some pictures for you to see my question is how hard is it to fix my problem? I really hate grinding second gear because i know its going to go out soon if not fixed. Just looking for some advice for my big beast. Thanks,
__________________
-1986 F-150-4 Speed Granny-302 V8-4x4-6" BDS Susp. lift-3.55 Limited Slip Rear-32x11.50/R15 BF Goodwrich MT's-Quad Shocks Front and Rear Sway Bars.
-1991 F-150-4x4-4.9 I6-Mazda 4 Speed With Over Drive-3.08 Gears Open Diffs. NO Sway Bars-Single Shocks-Dual tanks-Stock 31-10.50/R15 Alloy Rims.
  #2 (permalink)
Old 05-16-2008, 03:00 AM
81-F-150-Explorer is gaining momentum as a positive member of FTE.81-F-150-Explorer is gaining momentum as a positive member of FTE.
Quote:
It's difficult enough, that when the tranny was apart to replace the syncros I woluld go ahead and get the whole thing rebuilt. One thats already rebuilt, or a decent one out of the wrecker may be a better option too.
You don't have to grind the gear. Just double clutch it like you would a big truck with a transmission without syncros.
When shifting from 3rd to second, when the tranny is in neutral, let your foot off the clutch and rev up the engine, then throw out the clutch and when the RPM of the engine matches what it should be running for second gear, it will slip right in, without grinding. If you haven't done it before it takes practice, but it will get you by until you can fix it. Or you can double clutch it forever until something else breaks in the tranny or something else wears out.
Good Luck.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
