Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 08:45 PM
Welk49 is starting off with a positive reputation.
HPO System
Is anyone here running a 99-03 Pump on there OBS Truck, does it mount right up with no, or little mod, and have you noticed a difference in power/performance
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-15-2008, 09:00 PM
tjbeggs's Avatar
Fisher of Men
tjbeggs has a very good reputation on FTE.tjbeggs has a very good reputation on FTE.tjbeggs has a very good reputation on FTE.
Quote:
Yep I am. The key is that as long as your truck is a 96 or 97 your good for a direct bolt in. It you have a 94.5 or 95 you need to do some extra work.
I seem to have lost the write for the mod if you have an early truck but some one will jump in with it if you need it.
I did notice a nice increase in performance. Its not blow your top amazing but especially with the injectors I am running it was noticeable.
__________________
Tim
Proud User of "The Cure"
For sale- 95 accelerator pedal, Gray interior and dash part, cab and more PM your request!
Click the Picture for wiring diagrams, tech info and Pictures!
  #3 (permalink)
Old 05-15-2008, 09:03 PM
Well my plan was to run stage 2's I have a 96, so I will have to look into to swapping out the pump. Thanks
  #4 (permalink)
Old 05-15-2008, 09:16 PM
barebackjake's Avatar
barebackjake is starting off with a positive reputation.
a terminator twin pump or a pulse is great with 2's!!
__________________
97 F250HD 4x4 supercab 5sp 270k mi
4 link on air front and rear
2000 F350 CC 4x4 (wifes)
RIP CHRIS. 03/09/05
  #5 (permalink)
Old 05-16-2008, 06:49 AM
Neal 97 250's Avatar
Neal 97 250 is gaining momentum as a positive member of FTE.Neal 97 250 is gaining momentum as a positive member of FTE.
Yup Jake is right I understand the pulse is a good choiche. Although at $13xx.00 I opted for the SD pump it is a 17* pump. I have stage II's but they are 180 cc and I can still set the CEL a bit. I wouldn't go that big unless you plan on getting a pulse or stacking the pumps, which is in my future. The 17* pump will do you fine with II's at 160cc. Look on e-bay or International can get it for you for around $400 but they have a VERY high core charge so be sure you give them your core. The dealer is unreasonable.
__________________
97 F250 7.3PSD
X-Cab, SWB, 4X4
5spd, 4.10gears
3.5” DP, 4” Exh.
AFE Intake
FPR,BDP 140v IDM,CCV,HPX
Rosewood Stage II's
6 pos. TW chip, wow !!
'00 Excursion 7.3PSD 4X4
6637 intake
drill/slot rotors
Neal's Pics
  #6 (permalink)
Old 05-16-2008, 10:26 AM
secondarychaos's Avatar
secondarychaos is starting off with a positive reputation.
heres a slightly off topic question:
How is the HPOP driven?
__________________
Dan- Proud owner of:
1996 Ford F250 powerstroke diesel
Biodiesel processor being redesigned.
Next mod: a small aircraft to sit on a trailer behind the truck
www.homebuiltaircraft.com
  #7 (permalink)
Old 05-16-2008, 10:44 AM
FFemt5287 is starting off with a positive reputation.
gear driven, i believe off of the camshaft
__________________
1997 F-350. 7.3l PSD. zf5. 4.10 l/s. 4x4. Single cab/8ft bed. SRW. Boost/pyro. 4" straight stacks w/ raincaps. 160cc injectors. D66 turbo. TW chip. ValAir ceramic clutch. FPR shim. 6637 filter. 140,000mi.
ORDERED: BDP 140v IDM
NEXT: 230cc inj, head studs, IC, N20.
  #8 (permalink)
Old 05-16-2008, 11:06 AM
Quote:
kinda makes sense, would take a lot for that.
__________________
  #9 (permalink)
Old 05-16-2008, 12:37 PM
Yes the gear is under the HPOP reservoir and is direct gear driven.
__________________
97 F250 7.3PSD
X-Cab, SWB, 4X4
5spd, 4.10gears
3.5” DP, 4” Exh.
AFE Intake
Rosewood Stage II's
6637 intake
drill/slot rotors
Neal's Pics
  #10 (permalink)
Old 05-17-2008, 06:20 PM
RubberDuck's Avatar
Death Row Inmate #1
RubberDuck has a good reputation on FTE.RubberDuck has a good reputation on FTE.RubberDuck has a good reputation on FTE.
Welk, here's a writeup on doing the pump install. At the end of the thread is the real torque specs. In my writeup, I didn't have them. Enjoy
http://www.ford-trucks.com/forums/53...ml#post4017748
__________________
RubberDuck
1995 F350 Crew Cab 4x4 dually
DIY Stage 2's
T.E. SD HPOP
Tymar HPX
FPR 70psi
RSB Diesel 140v IDM
Tymar Intake
3"DP to 5" stacks
DP Tuner 2 pos. w/ custom switch
Hot Pedal
Gear Vendors OD
Good bye No.3 I'll miss you.
RIP #17
  #11 (permalink)
Old 05-17-2008, 08:05 PM
thanks for the help Duck, much appreciated.
  #12 (permalink)
Old 05-17-2008, 08:26 PM
FARM69's Avatar
FARM69 is starting off with a positive reputation.
Neal how do you like the 180's? Are you running a tuner?
__________________
97' F250HD 4x4 Intercooled Powerstroke 5 Speed LB / Stage II (180cc) Injectors / 10 K / 5er
A-Pillar AutoMeter Cobalts [Boost, Pyro, Water Temp]
4" Straight / EBPV Exhaust Brake / 6637 / CCV / 203 Stat / HX50 (19cm) is ready to mount!!
  #13 (permalink)
Old 05-17-2008, 08:31 PM
Robbgt's Avatar
Robbgt is gaining momentum as a positive member of FTE.
Quote:
Not to answer his question for him... But he's got TW burns for the 2's and as i'm sure you know the 17º HPOP. .... ok sorry Neal you go
-Robb
__________________
97 F-350 XLT 4x4 PSD, E40D, 3.55's, 153K, 6637, 140V IDM, HPX, FPR Shim, Hotfoot, Tymar DP, Dual Exhaust, T/C Lockup mod, new GP's, Stancor GPR.
>>FOR SALE: FTE Classifieds<<
  #14 (permalink)
Old 05-19-2008, 07:02 AM
Quote:
-Robb
No prob Robb. Thanks for answering I only get internet at work right now so I have been down for the weekend.
Farm I love the II's and yes it is a TW. My next job WILL be the intercooler 'cause I don't think I will be able to pull my 5er with the temps I am seeing right now.
__________________
97 F250 7.3PSD
X-Cab, SWB, 4X4
5spd, 4.10gears
3.5” DP, 4” Exh.
AFE Intake
Rosewood Stage II's
6637 intake
drill/slot rotors
Neal's Pics
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
