Knocking Sound Coming from 5.4L - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 05-15-2008, 09:35 PM
SPreston2001 SPreston2001 is offline
SPreston2001 is starting off with a positive reputation.
Hi guys a friend of mines has a Expy with a 5.4L and it has a knocking sound coming from the engine. The sound seems to be louder towards the bottom of the motor, and im trying to help her decide if she should sell the thing immediately, or if its something that may not be too expensive. The knock doesnt seem to have any effect on the power or performance of the truck, but its kind of annoying and takes away from the overall beauty of the beast! Where should I start? Is this common on these engines? Any and all help will be appreciated!
Old 05-15-2008, 11:05 PM
sbclemens sbclemens is offline
sbclemens is starting off with a positive reputation.
How is the oil level? Does the CEL come on? Is the knocking just occur when you first start the engine? Does the knocking increase when the rpm's increase? Can you pin point the location of the knocking? What type of oil filter are you using? Is it a knocking or a ticking?
Old 05-15-2008, 11:06 PM
Please provide as much information as you can. Oh, by the way, welcome to the fourm.
Old 05-15-2008, 11:24 PM
Thanks for the welcome. She just got the truck two weeks ago. This past weekend I changed the oil to Mobil 1 5w-30 full synthetic with a Mobil 1 oil filter. The oil level and pressure is fine, check engine lights is not lit, and the knocking happens at startup and doesnt go away. The knocking also gets faster with increased acceleration. And the sound is definetely a knock not a tick. Thanks for the help.
Old 05-16-2008, 01:11 AM
eallanboggs eallanboggs is offline
eallanboggs is starting off with a positive reputation.
This vehicle has only been owned for 2 weeks and now it has a knock? That's pretty suspicous. What it thoroughly checked out before it was purchased? Did you pop the hood and listen to the motor BEFORE you put your money down? Was it bought AS IS? The knock is due to a spun bearing on crank or rod because it was run low on oil. Very bad news. This means a teardown. You won't know whether it's a rod or main until you pull the pan. You must examine the journal where the spun bearing is located for damage. If you have scoring or gauling the crank has to come out to be turned. You can tell a spun bearing because the locator tab will be snapped off. You should plasti-gage all the mains and install new shells. You have to do the big ends too. Good luck! You should do what the previous owner did to you and look for a buyer that doesn't pop the hood before buying a vehicle.
Old 05-16-2008, 02:21 AM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Quote:
Considering that they're the type of people discussing passing the truck off on some other unsuspecting soul, I'd call it poetic justice. I see someone with a future as a used car salesman.
Old 05-16-2008, 09:01 AM
Is there any warranty on the vehicle?
Old 05-16-2008, 11:58 AM
Lol no I wasnt present when she brought the truck, I do know how to shop for a vechicle and besides internal engine work im pretty knowledgable about automobiles. The truck wasnt knocking when she brought it, or she would have never told me about it she would have just thought that was the way the truck was supposed to sound. The truck was brought from a private owner so theres no warranty. I think I'll take it to my mechanic on her next day off and see what they say. Thanks
Old 05-16-2008, 01:22 PM
Don't you find it curious that only after 2 weeks the truck develops an engine knock which wasn't there when it was purchased a few days ago. That's a red flag for sure. It's too late now. You can either run it until it fails or bite the bullet and pull the pan. This is a major tear down.
Old 05-16-2008, 05:42 PM
NaviShock NaviShock is offline
NaviShock is starting off with a positive reputation.
You sure it wasn't knocking when she was looking at it? Maybe she didn't notice it until she bought it a drove it more. Man, if not what a heck of a thing to happen after only two weeks. Spun bearings don't typically happen overnight. It definitely sounds like that and like others said, engine rebuild time.
Old 05-16-2008, 07:52 PM
Well good news I was able to squeeze it in at the Ford Stealership today, and come to find out its just a exhaust leak coming from both manifolds. I went and picked up both manifolds and gaskets from NAPA today and I will replace them both tommorrow morning.
Old 05-16-2008, 08:12 PM
I thought a bad gasket or crack on the exhaust manifold would cause more of a "ticking" than a "knocking".
Old 05-16-2008, 08:24 PM
Yeah me too but they had the truck for about 5-6hrs and they ran a compression test, pulled the pan, and did a couple other things and found nothing wrong with the motor itself. I have had exhaust leaks on a couple of my old schools (85 monte, 77 cutlass) and they sounded terrible but this sound was a little different. I will post again tomorrow and let you guys know how it sounds after I replace the mani's.
Old 05-16-2008, 09:44 PM
Wow, heck of a knocking sound from an exhaust. Glad to hear it wasn't anything major.
Old 05-16-2008, 11:27 PM
While your at it, you should replace the studs with stainless steel. Coat them with anti-seize compound. Also, when installing the gaskets, use a dab of rtv or other adhesive to hold them in place while you fit the manifold on. Spray down the EGR tube and all the studs the night before with WD-40 or some other penetrating oil of choice.
Knocking Sound Coming from the engine Tamtamk 1997-2006 Expedition & Navigator 5 11-03-2016 04:45 PM
Light Tick/Knock/Click Engine Sound afr 2007 - 2014 Expedition & Navigator 7 04-25-2015 04:24 PM
2000 F250 Ticking/Knocking Noise F350Man79 1999 to 2016 Super Duty 11 07-28-2014 08:59 PM
05 f350 5.4 knocking 120K Fisher Roofing NJ 1999 to 2016 Super Duty 11 01-18-2014 03:10 PM
5.4 with 200 Miles, light knocking sound? jdoc Modular V8 (4.6L, 5.4L) 10 09-18-2004 07:12 PM
Tags
1997, 2005, 54, 54l, bearing, crankshaft, engine, ford, knock, knocking, motor, replacing, sound, started, tear
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
