Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 08:19 PM
2 stroke man is starting off with a positive reputation.
trans break-in? trans news too.
do i need to provide a break-in period for my trans? the builder says no, he says to take it straight out and use the crap outta it to see if it will last off the bat.
he said it burned out starting with reverse. he asked if i had been backing up huge loads long distances, but i havent. what would cause that?
__________________
"i'm like a shopaholic on cocaine.....except not on cocaine"
-the GF
97 Stroker. not enough mods. only Superchip, K+N, DP, Tranny, Trans Cooler, Rims, hood, all the other nice accessories. FOR SALE
  #2 (permalink)
Old 05-15-2008, 08:56 PM
Stroker09's Avatar
Stroker09 is starting off with a positive reputation.
I just had mine rebuilt. He told me to take a 1000 mile break in period then to bring it back up so they can make sure everything broke in good and stuff. The guy that did my uncles told him to go out and run it hard to work the tranny good, just dont pull for 500 miles. So not totally sure but im following the 1000 mile break in that the guy told me. That 1000 miles includes no "heavy" pulling.
Steve-
__________________
97 F250 PSD. Intake. 4in exhaust. 3in downpipe. Fully built tranny, boost, trans temp and pyro gauges...not a bad set up for a 17 year old. lol
  #3 (permalink)
Old 05-16-2008, 09:48 AM
MagKarl is starting off with a positive reputation.
Backing up huge loads is tough on them because you don't get any wind through the cooler, and it's often slipping and gets hot fast if you're pushing hard and letting up to correct steering, etc. If it was mine, I'd do a fluid and filter change in the first 1000 miles just for peace of mind.
__________________
1995 F350 XLT CC 4WD PSD 5 Speed
Rose 160cc Stage 1 injectors
Tymar intake
Autometer Pyro and Boost
Tymar 3-4" DP & 4" Exhaust
TW Chip
6.0L SD Intercooler
SD Captains Chairs
2001 Excursion Limited 4x4 V-10
  #4 (permalink)
Old 05-16-2008, 10:54 AM
rungunner is starting off with a positive reputation.
Trans
I am starting to see my trans slipping, i am curious to know what you paid to have yours re-built. How did you pick the shop to re-build it?
Thanks
  #5 (permalink)
Old 05-16-2008, 11:54 AM
reputation, ect. talk to them. see if they seem to know what they are talking about. see if any large businesses around ur area use them. a good build will be anywhere from $1600 up. be sure to get heavy clutch packs, a good solid flat-back convertor, and all that good stuff.
__________________
-the GF
  #6 (permalink)
Old 05-17-2008, 11:05 AM
IDMooseMan's Avatar
IDMooseMan is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by 2 stroke man View Post
...and all that good stuff.
That's part I'm not familiar with. What do you mean by "Flat back" for the TC? Did your tranny shop order a rebuild kit for you? Did you provide a rebuild kit to the tranny shop?
I want to get a TC and tranny rebuild so I don't have to worry when towing my travel trailer and hauling stuff (most likely less than 10K) for the non-truck owners I know.
What "good stuff" is everyone refering to? Where do I get it? How can I make sure the "good stuff" I want installed is the same "good stuff" the tranny shop installs?
__________________
Craig "IDMooseMan" Peters
1997 F-350 XLT 4x4 CC LB E4OD 4.10:1
FPR Shimmed to 70 PSI, 6637 Upgrade, ICP Resistance Mod
USAF SSgt 1983 - 1992
NAHC Life Member
1991 Wilderness 24M
Truck Pictures
FTE Fraternity of Blue Max
  #7 (permalink)
Old 05-17-2008, 12:38 PM
c00nhunterjoe's Avatar
c00nhunterjoe has a good reputation on FTE.c00nhunterjoe has a good reputation on FTE.
there are many upgrades you can do to your e4od to make it stronger. the obvious things are stornger clutches and steels, and a good torque converter. but there are other upgrades as well, such as swapping the cheap 4 pinion aluminum planetaries out for the 6 pinion steel units, a good valve body/shift kit, programming, changing the drum and swapping fluid holes to get more pressure to the clutches.
i have never checked his prices but at a quick glance Racerx automotive sells most, if not all, of the upgraded parts you would want to get if you were doing a total teardown and overhaul. that would be a convienient way to get it all in one place
__________________
97 F-250, 4.10's Auto, Superchip, All mods by c00nhunterjoe's performance shop http://community.webshots.com/user/c00nhunterjoe
http://youtube.com/c00nhunterjoe
  #8 (permalink)
Old 05-17-2008, 05:15 PM
IDMooseMan's Avatar
Thanks, Joe. That's the kind of info I'm looking for.
__________________
NAHC Life Member
1991 Wilderness 24M
Truck Pictures
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
