Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 08:17 PM
linesda is starting off with a positive reputation.
F250 5.0 fuel delivery trouble
I have a 89 F250 4x4 that has an aparent delivery fuel problem. The truck has a new Jasper 5.0 EFI engine, Both fuel tanks are new as well as the fuel pumps. After the engine was installed it ran fine for about 6 months then the truck just dies while driving it (like it ran out of gas). This happens on both front and rear tanks. If the truck sets for awhile it will start fine. It will run all day setting still but will only make it about 10 or 15 miles before it stalls out.
My mechanic has run out of ideas besides the ECU. Could this be the root of the trouble. If so I am having trouble finding an exact part match. How important is it to match this exactly.
The OME unit is marked as:
U9E
E9TF-12A650-AP2A OR E9TP-12A650-AP2A
I cannot tell if the fouth letter is a F or a P, Looks more like a P.
Any help or ideas would be appreciated.
Thanks
Linesda
  #2 (permalink)
Old 05-16-2008, 08:18 AM
Lazy K is starting off with a positive reputation.
I would guess at the fuel pump relay heating up. Someone else may have a better idea.
  #3 (permalink)
Old 05-16-2008, 02:18 PM
alz alz is offline
alz is starting off with a positive reputation.
89? Does it have a high pressure pump on the frame rail under the driver side?
__________________
1995 F150 4x4 SC 302 4R70W MAF
  #4 (permalink)
Old 05-16-2008, 06:38 PM
Yes it does have a third pump
Yes the truck does have a third pump. And that has also been replaced.
Linesda
  #5 (permalink)
Old 05-16-2008, 06:54 PM
flareside_thunder is starting off with a positive reputation.
how bout FF and have you pulled codes?Just cause the light don't come on doesn't mean they aren't there......Ford Fuel Injection will tell you how to pull the codes without a scanner...get em and post em up....
JR
  #6 (permalink)
Old 05-16-2008, 08:32 PM
dvldog458 is starting off with a positive reputation.
Sounds like that 3rd pump is faulty. Or its on it's way out.
__________________
1991 F-250 4X4 5.0L 6psi Powerdyne supercharger...stroker 408 in the works w/ 9psi
13" Lift 40" Boggers
2004 Excursion Limited 4x4 w/ 6.0L
SEMPER FI
  #7 (permalink)
Old 06-05-2008, 06:29 PM
3rd pump has been replaced
Thanks but the 3rd pump has been replaced twice. as well as both tank pumps twice. If you have any other ideas let me know.
Dave
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
