Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 08:14 PM
totalrecall is starting off with a positive reputation.
2003 4X4 4.0 - AC and TSB Help
Have a low milage 2003 4X4 with the 4.0. Runs fine, doesn't overheat, but on hot days if I get stuck for more than a minute or so at a light or traffic backup, the AC temp (Yes I have an AC temp guage in the dash) goes up at least 10 degrees and you can really tell. As soon as I get going again right back down to super cold. No sign of overheating, engine temp guage stays right where it should be. Also sometimes get the engine hooting at low RPM, don't know if it's related.
So did some searching, does anyone have:
TSB: 17217
TSB: 16309
TSB: 042511
TSB: 17085
Looking for something simple to help - hopefully. It generally seems cold enough, so I haven't had any guagues hooked up yet - I realize I could be 1/4 can or less low on Freon, but the AC works so well otherwise I don't know.
Thanks
Mike
  #2 (permalink)
Old 05-15-2008, 08:22 PM
heymrdj is starting off with a positive reputation.
It's the fact that you have to remember how an A/C system works. The A/C condenser takes the freon that's given away it's cold to your cabin air, and lets your engine fan pull air over it to cool it again before it goes back to the compressor. The engine fan at idle however is good for moving high volumes of air, but not over your AC coil. So your freon isn't chilled as well, causing it to not be able to chill the air blowing into your cabin. When you're running down the highway though, you are moving air at 35, 45, 55mph ect ect over your coils just because your moving, resulting in higher efficiency.
If you want better AC performance at an idle, replace your engine fan with electric fans. I'm wanting to put a dual 16" kit on my 04 Expedition (your Explorer will probably only hold dual 14" at biggest) from Troyer. One fan dedicates itself entirely to blowing over your A/C coils, at about 2700cfm (i may be wrong on that for the 16" model), which is a GREAT airflow boost compared to what your engine fan is pulling over it.
Now this isn't to say you may not still have a problem. But at 03, low freon is out of the question unless your leaking. I hope your problem has to do with physics and temperature, and nothing like an actual physical problem.
Best luck mate
__________________
2004 Expedition
Eddie Baur 4x2
5.4L 2v Triton V8
NEW: 2 3/4" pipe with Flowmaster Super 50 Delta Flow Muffler and 3.5"x18" echo tip WOOT
Upcoming:
20" Giovanni wheels
all corners air suspension
  #3 (permalink)
Old 05-18-2008, 11:54 AM
beater79's Avatar
beater79 is starting off with a positive reputation.
He is right, thats more than likely your cause. I would just keep an eye on your eng temp gauge to, if it starts going up when sitting at a light you could have a blockage in either the a/c condensor or the radiator. I think I have to agree that you more than likely have no issues.
__________________
79 F-150 short bed, 400m, 4spd, 4x4, 4" rancho lift
96 explorer 4.0 auto, k&n filter, stock
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
