Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 07:16 PM
twisted limb is starting off with a positive reputation.
Axle pivot bushings
After replacing my right front ball joints I got a clunk when coming to a hard stop.I figured now that the ball joints tightened things up it showed something else was worn.I believe it is one of the axle housing pivot bushings.Question I have is there a metal sleeve thru the center the bolt goes thru?I see what appears to be one where the rubber is pushed back.Old posts on here say to put a jack under the half working on and lower enough to replace.Should I place a jack elsewhere and should the whole front end be off the ground.thanks
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
