Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 06:50 PM
7375highboy is starting off with a positive reputation.
28 spline axels?
I have a 79 f150 2wd,that has a 450 hp 351c in it. I need to put better gears in it and I have a set of 389,s and a posi 28 spline. The only problems is my axels in my truck are 31 spline. Did ford put 28 spline axels in these trucks? If so I need a set.
thanks Jesse
  #2 (permalink)
Old 05-15-2008, 07:00 PM
77Explorer is starting off with a positive reputation.
If you have 31 spline axles use them!
I just broke a 28 spline unit behind my 351W been outside in this rainstorm pulling my poor 9" apart.
  #3 (permalink)
Old 05-15-2008, 07:16 PM
Sgt Wonderful's Avatar
Sgt Wonderful is gaining momentum as a positive member of FTE.
28 spline count
I have 28 count on mine, from the factory. 79
__________________
1979 Ford F-100 Custom
300 six with P/B P/S A/C Cruise A/T. Power Locks and Windows. (with a new rust hole in the floor board)
(My daily driver) in the summer time
  #4 (permalink)
Old 05-15-2008, 09:24 PM
my axle..
  #5 (permalink)
Old 05-15-2008, 09:36 PM
Grumpy Ford Parts Guru
NumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant future
28 or 31 spline axleshafts.
1973/79 F100's / 1975/79 150's came both ways, it depended on the application.
__________________
Bill / Retired Ford Partsman ~ 1962/97
Part number research: Trucks 1948/02 / Cars 1949/91
1963 Galaxie 500XL / 1965 F100 Styleside / 2008 Fusion
  #6 (permalink)
Old 05-16-2008, 12:05 PM
ChaseTruck754 is starting off with a positive reputation.
As others have said - 28 & 31 were available, but you will definitely want to go with the 31s!
__________________
Have you flown a ford lately?
1938 Ford Pickup = hot rod
1989 Ford Ranger = never gonna be done...
1974 Ford F250 4x4 Crew cab = tow rig
1972 Alfa Romeo GTV
1991 Dodge 250 cummins - motor donor
1994 Honda crf 50 w/ 108 stroker motor
1999 Toyota Tacoma 4wd = daily driver/weekend toy
  #7 (permalink)
Old 05-16-2008, 04:57 PM
duste is starting off with a positive reputation.
With that kind of HP stay away from the 28 spline, I twisted a set of 28 off with a stock 429, changed to the 31's and it never came apart again.,
__________________
If it's a FORD, it's therapy. For anything else , it's called WORK.
76 F100 300 6
79 F150 302
79 F150 351M to a 429 (best sleeper ever)
79 F150 460 -current toy
2006 F150 XLT XTR S/ CREW
All 2X4's
  #8 (permalink)
Old 05-16-2008, 05:00 PM
7866ford is starting off with a positive reputation.
In my experience the 28 spline only came in the 2wd. very rarely did they have 32. But every 4wd ive worked on was a factory 32 spline.
  #9 (permalink)
Old 05-16-2008, 05:37 PM
TXFarmallFan is starting off with a positive reputation.
Yeah. I only thought 4x4's had the 31 spline.
  #10 (permalink)
Old 05-16-2008, 05:40 PM
my truck have 31 spline and it is a 79 2wd.
  #11 (permalink)
Old 05-17-2008, 08:29 AM
I've had nothing but 2wd's and several rear gear changes over the years and have found both 28 and 31 spline axles. Not sure but the 31 may be part of the 150 HD with the 6050 GVW. I know my truck has the factory power train with a 3.50 LS 31 spline 9 inch.
__________________
76 F100 300 6
79 F150 302
All 2X4's
  #12 (permalink)
Old 05-17-2008, 10:05 AM
psquare7575's Avatar
psquare7575 is starting off with a positive reputation.
I just upgraded to 31 spline axles from 28 splines over the winter.
__________________
75 H/O Project: Revival
78 Mercury Cougar XR7 523/c6/3.55:1
79 Ford F100 XLT 2WD 460/c6/3.55:1
93 Cavalier Z24 Clone
  #13 (permalink)
Old 05-17-2008, 10:26 AM
79Indy is starting off with a positive reputation.
Quote:
I have the 6150 GVW package and I still got stiffed with 28 splines.
__________________
'79 F150 Indy 500 Pace Truck Edition
302/C6/9"
  #14 (permalink)
Old 05-17-2008, 11:50 AM
It depends on what options came on the truck. If you're looking for 31's then start with the 4wds - as I don't remember ever seeing a 4wd w/ 28 spline. That doesn't mean the genious that is ford never did it though. Trying to find 31 spline in a 2wd is more of a crapshoot. You may get lucky and find one with 31's - you may not.
__________________
1972 Alfa Romeo GTV
  #15 (permalink)
Old 05-17-2008, 06:07 PM
LxMan1's Avatar
LxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to behold
All 300 6 cylinder trucks that I have checked are 28 spline. V8 trucks are 31 spline.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
