Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 05:59 PM
jrv jrv is offline
jrv is starting off with a positive reputation.
replaced ignition accuator cam, however
'90 F150, after i put every thing back, still won't start. wondering if i missed something? i turn the key, hear the fuel pump but no cranking from starter. could this be related to my moving around the ignition switch during process?
thanks in advance.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-15-2008, 07:00 PM
F150xlt is gaining momentum as a positive member of FTE.
There is some adjustment at the ignition switch which is bolted to the middle of the steering column.
  #3 (permalink)
Old 05-15-2008, 08:34 PM
jrv jrv is offline
installation instructions said to find midlash, which i was not exactly sure what that was. what i did after putting in place was to make slight shifts to switch (using the slots in frame of switch) so that i would get the key to function as well as i could.
is it possible that making further slight adjustments would make the difference? is this just a trial and error method, or is there a way to be sure that it is located properly?
  #4 (permalink)
Old 05-15-2008, 10:24 PM
First disconnect the negative battery cable before making any adjustments to the ignition switch.
I don't know if it's possible but you could be off a tooth on the gear part of the actuator which could cause not enough actuator rod movement.
The ignition switch has the following positions.
Accessory
Lock
Off
Run
Start
The way the manual says to adjust the ignition switch is to first remove it.
Then manually place the ignition switch in the Lock position. Insert a 5/64 inch drill bit into a hole that is on the side of the ignition switch to keep the switch in the Lock position.
Place the ignition key switch in the Lock position and remove the key.
Insert the actuator rod onto the back of the ignition switch. Bolt the ignition switch to the steering column. Manually move the ignition switch back and forth so any excess play is the same in either direction. Tighten the two nuts that hold the ignition switch to the steering column.
I would move the ignition switch back and forth untill you have all 5 key positions. In your case you say you have no start postion. That would indicate the ignition switch needs to be moved towards the steering wheel. (When you turn the ignition key clockwise the actuator rod moves downward towards the floor).
  #5 (permalink)
Old 05-16-2008, 08:09 AM
dave2 is starting off with a positive reputation.
The Reader's Digest condensed version is: get access to the switch, loosen nuts enough to slide, turn key "OFF", and:
Slide in one direction until something happens (dash lights) back the other way until "", then back to the middle. Snug nuts a little and fine tune, then tighten and see how it works.
Dave
__________________
1990 F250 4x4 5.8 5sp reg cab XLT.
All stock(???)
  #6 (permalink)
Old 05-16-2008, 06:14 PM
jrv jrv is offline
had to adjust the gear at end of key cylinder so i could get all positions, then tweaked the ignition switch acouple times (moved toward the steering wheel) and she started up!!!!!!!!!!!
thank you for your help!!!
hope i never have to replace an accuator again.
  #7 (permalink)
Old 05-16-2008, 08:49 PM
Talking
You saved your self a couple hundred dollars.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
