Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Brakes, Steering, Suspension, Tires, & Wheels
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 05:33 PM
rungunner is starting off with a positive reputation.
Brake light
Driving down the road the brake light will pop on for a minute and then go off. what do you think would cause this problem? Brakes are new all the way around and work very well. 1997 f-350/ 7.3 diesiel
Thanks
  #2 (permalink)
Old 05-15-2008, 05:38 PM
alchymist's Avatar
alchymist has a good reputation on FTE.alchymist has a good reputation on FTE.
My guess would be a loose brake switch...if it's a mechanical switch on the brake pedal and it's loose, it can bounce around and activate itself......easy enough to check ...should be mounted next to the brake pedal arm.
__________________
TRITON V10 - THE BEST KEPT SECRET -
(But word is getting out).
'08 F350 Scab 4X4 V10
07 Gulfstream Prarie Schooner
'05 Escape
'04 Focus
Passed the exam today! I am now a licensed instigator!
  #3 (permalink)
Old 05-15-2008, 06:20 PM
projectSHO89 is gaining momentum as a positive member of FTE.projectSHO89 is gaining momentum as a positive member of FTE.
If you are referring to the red BRAKE warning lamp, check your brake fluid level.
If that's okay, the e-brake switch is probably flaky or the e-brake lever is not retracting completely.
Steve
__________________
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #4 (permalink)
Old 06-26-2008, 02:47 PM
Switch
I replaced both switches and still have the brake light come on. I think something is hanging up in the right rear wheel because after driving for awhile the rim gets hotter than drivers side. I changed the brake caliper on the right side and the drum and shoes are new and everything looks good, I am not sure what is going on but it is driving me nuts. Any suggestions?
  #5 (permalink)
Old 06-27-2008, 07:51 AM
Lazy K is starting off with a positive reputation.
If your truck has a vacuum brake booster then the vacuum pump may be down a bit. Low vacuum can cause a warning light. If you have hydraboost then I don`t know about it.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
