Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Audio & Video Systems, Navigation, Satellite Radio and Mobile Electronics
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 05:33 PM
Snoop1965 is starting off with a positive reputation.
simple question- stock radio wiring
95 F150xlt
previous owner swapped in a Pioneer cd player...cd player had fruit juice put in it...does not work.
i have the stock radio and would like to reinstall it. there is the antenna receptical and a couple rows of flat pins- 6 pins in one row and 8 in the other (vertically).
as it sits now i have 2 wires with male plugs- one red and one white and a plastic female thinger with about 20 some pin holes and a bunch of different colored wires going into it- two green/black on each end, a red, a blue, and orange i think....probably more.
what do i do to wire the stock radio back in?
  #2 (permalink)
Old 05-15-2008, 08:50 PM
Truckin4life has a good reputation on FTE.Truckin4life has a good reputation on FTE.Truckin4life has a good reputation on FTE.
the plug your talking about... is it the one that plugged into the back of the pioneer unit? If so then follow it back and it should connect to the factory harness... Just disconnect the pioneer harness and the stock harness should clip right in to the factory radio...
__________________
Don
Stg's Minions: 12 volt specialist
1995 f-250 ext. cab, lb. 4x4, 5.8 5 speed. Performance mods, and a heavy foot.
Quote:
Originally Posted by STGFordCrazy04 View Post
X2 and hes not talking about truck nuts
Welcome to the Minions house.....Giving correct answers since 2007.
  #3 (permalink)
Old 05-15-2008, 09:17 PM
found the old plugs...got it all connected but no power...will have to check fuses and connections tomorrow.
thanks.
  #4 (permalink)
Old 05-19-2008, 11:06 AM
BradyCouchman's Avatar
BradyCouchman is gaining momentum as a positive member of FTE.BradyCouchman is gaining momentum as a positive member of FTE.
the radio might think that it got stollen and will not work with out a code getting put into it or getting reset...
__________________
1970 F-350 Crew Cab long bed
06 Focus ZX3 5 Speed (DD)
SoCal/Hawai'i FTE
Join our Chapter *HERE*
Quote:
Originally Posted by joshc_guitar View Post
its called Mobile City Tx it is a trailer park with a government.
  #5 (permalink)
Old 05-19-2008, 12:09 PM
I dont think the 95's had that security on them... If the stock deck is messed up ive got mine still i could ship ya.
__________________
Don
  #6 (permalink)
Old 05-19-2008, 07:44 PM
turn out the stock radio i have is shot too....and the sleeve the radio slides into is set up for a pioneer deck...and walmart has one for under a hundred bucks...so i'll go that route.
thanks for the offer Truckin4life...very cool of you!
  #7 (permalink)
Old 05-19-2008, 09:21 PM
Beerstalker's Avatar
Beerstalker has a good reputation on FTE.Beerstalker has a good reputation on FTE.Beerstalker has a good reputation on FTE.
As far as I know the metal cages that aftermarket radios slide into are all compatible with each other. So you shouldn't be stuck with a Pioneer deck if you would rather try something else.
Also, I suggest shopping online as you can probably get a much better radio for the same money you would be paying to buy something from Walmart. One place I have been very happy with is Car Audio Video - Car Subwoofers - Car Amplifiers and Speakers
__________________
2007 F350 Lariat, CC, LB, 4x4
4.5" DR Lift w/35x12.5r20 Toyo Open Country M/Ts
Keystone Restyling Ram Air Hood W/Airaid Intake & Pre-filter
Recon Smoked Cab, Mirror, and Brake Lights
MSD Dashhawk w/A Pillar Mount
Dieselsite Coolant Filter
Lund Eclipse Window Vents
Weatherguard Toolbox
  #8 (permalink)
Old 05-23-2008, 08:24 PM
so i got a cheap panasonic...got the adapter harness- got it wired together...one blue and one orange wire left over- wired them to same colored wires (something removal and backup batt resp) in the truck...had to bypass the factory plug with a heavier black wire from the stereo plug to a heavier black with green stripe wire behind the factory plug (it had been cut and connected to a black wire on the old stereo plug-ground?)...hit the key and power button....NOTHING.
fuses are good.
any ideas?
  #9 (permalink)
Old 05-25-2008, 09:52 PM
so i got the thing hooked up best i can figure...riding around for two days hoping for a miracle i guess...miracles happen with them Fords...kinda.
i turn the headlights on and low and behold...pretty blue lights in the center of the dash.
i obviously have the radio wired in with the headlights somehow...i turn the lights off and lose all presets...like disconnecting the battery.
any ideas on that?
  #10 (permalink)
Old 05-26-2008, 08:32 PM
Old Ford Blue's Avatar
Old Ford Blue is starting off with a positive reputation.
Sounds like you hooked the switched hot to the dash lighting wire. Either drive with your parking lights on, or get a multimeter and figure out which is which.
__________________
Gabe
67 F-100 Ranger Hipo 390 4bbl\3 speed
73 F-100 Custom 302\auto---The best part is....it was FREE!
along with several other trucks and jeeps.
__________________
I decided that if the assembler could get stoned and put these trucks together, I should have no problem fixing them. LOL
__________________
  #11 (permalink)
Old 06-01-2008, 04:56 PM
still don't have this figured out.
with all other wires connected to the harness (the ground wire bypasses the harness directly to the truck ground) and with the key in the ACC position i take the ACC wire from the radio and jump it across the harness from the truck hitting each terminal i get no power to the radio...i turn the parking lights on and i got power.
i don't get it.
  #12 (permalink)
Old 06-01-2008, 05:47 PM
madsonp is starting off with a positive reputation.
Quote:
fuses are good.
any ideas?
Look at your owners manual for the Panisonic, I believe it'll show that the orange wire needs to be connected to a source that has power all the time (i.e. battery positive) which is the green/yellow wire on your harness. If this is what your manual shows this should take care of your problem. The left over blue wire is a remote on signal wire for an amplifier which you don't have, so don't connect it to anything. Here's the wiring on your stock radio harness and what each wire is for, compare this with your owners manual for your Panisonic and hook up accordingly.
Constant 12V+ Green/Yellow
Switched 12V+ Yellow/Black
Ground Red or Black
Illumination Blue/Red
Dimmer n/a
Antenna Trigger n/a
Antenna Right Front
Front Speakers 5 1/4" Doors
Left Front (+) Orange/Green
Left Front (-) Black/White
Right Front (+) White/Green
Right Front (-) Black/White
Rear Speakers 6" x 8" Side Panels
Left Rear (+) Pink/Green
Left Rear (-) Pink/Blue
Right Rear (+) Pink/Blue
Right Rear (-) Green/Orange
__________________
99 Expedition EB 4x4 5.4L (mine)
97 Expedition EB 4x4 5.4L (wifes)
77 E-250 4x4 Van 460ci (gas pig)
76 E-350 Motorhome 460ci (another gas pig)
42 Ford 9N Tractor (old pig)
Are you talking to me ?
  #13 (permalink)
Old 06-01-2008, 08:38 PM
Sorry, I believe I made a mistake. The Orange should be your lumination, the Yellow wire from your Panisonic should should be your constant power. Again check your manual to make sure.
__________________
  #14 (permalink)
Old 06-04-2008, 09:45 AM
Bikeitswift is starting off with a positive reputation.
...should be good for "Light Rock"...
__________________
At the Lake
  #15 (permalink)
Old 06-08-2008, 08:01 PM
Did you ever get it hooked up yet ????????????
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
