Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Aerostar
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 05:33 PM
ridgerider3's Avatar
ridgerider3 is starting off with a positive reputation.
Amount of trans fluid
Just got done bringing my '92 Aero back to life with a "junkyard" fix.
Dropped out the old crank, and put a new Standard/Standard crank in it's place.
She fires up and runs with no noise {other than the PS pump} but the trans wont move her.
How many quarts does it take to fill up the trans once it's dry?
  #2 (permalink)
Old 05-15-2008, 06:14 PM
Kruse is starting off with a positive reputation.
Quote:
Originally Posted by ridgerider View Post
Just got done bringing my '92 Aero back to life with a "junkyard" fix. Dropped out the old crank, and put a new Standard crank in it's place. She fires up and runs with no noise {other than the PS pump} but the trans wont move her.How many quarts does it take to fill up the trans once it's dry?
Maybe a little clarification is needed for me.....
Depending on how much tranny fluid is needed, 4-8 quarts. But that is a guess depending on if you just dropped the pan or the tranny was completely dry. I guess that is why they have dipsticks.
I shudder to think, but......if you had the engine and tranny separated, you put the torque converter in the tranny properly didn't you? I've seen a few guys screw up the front pump in the tranny by improperly installing the torque converter in the tranny and just pulling the engine and tranny together with the bolts. Please tell us that you properly installed the torque converter.
BTW, welcome.
  #3 (permalink)
Old 05-15-2008, 07:11 PM
xlt4wd90 is starting off with a positive reputation.
I think the capacity of the A4LD is around 9-10 quarts. Even 1 quart low can cause it to not engage.
But Kruse has a good point about properly connecting the transmission to the engine. The most secure method is to first seat the torque converter onto the input shaft. As you turn the converter by hand, it should slip onto the shaft in 4 discrete steps. When you have it properly seated, it should just scrape the bell housing as you turn it. Then you bring it into the back of the engine, aligning the converter studs to the holes in the flex plate.
  #4 (permalink)
Old 05-16-2008, 11:09 AM
ygoldsberry is starting off with a positive reputation.
ok well im the one that put the tranny back on this thing didnt know there was any specific way to do it so do you think that we should pull the tranny an redo it ?
  #5 (permalink)
Old 05-16-2008, 02:36 PM
I would think that if you crushed the pump, you would hear a lot of noises when the engine starts. Check the simple thing first; the fluid level. If that's OK, then the problem is elsewhere.
Since you have the ability to remove the transmission, I would say go ahead and do it and check to see if you've damaged anything. But beyond this point, I don't know how you would diagnose any non-obvious problems. The pump damage that results from improperly seating the converter is usually inside, so other than obviously loose or mis-aligned shafts, I don't know how to tell without taking it apart (or unusual noises as I mentioned).
  #6 (permalink)
Old 05-16-2008, 09:36 PM
Just what would the noises sound like? On startup there was a "clicking" noise like a bolt tapping on a loose piece of metal, and a "whine" that I am sure is just the power steering pump. I was able to move the van off the ramps it was on, but it took a lot of throttle to get it to move. I just figured that was from low fluid. She was moved about 3 to 4 feet back. Other than that, the motor ran for about 5 mins.
Going to Pull the tranny back and reseat the converter as suggested. Anything special I should look for while doing this?
  #7 (permalink)
Old 05-17-2008, 12:06 AM
I heard the noise described as kind of a grinding coming from the transmission. That the van is moving at all indicates the transmission is at least partially working. The behavior sounds a lot like low fluid. Are you sure the fluid level is OK?
Sorry to sound morbid, but if you had not properly seated the converter and crushed the pump, the damage has already been done. But at this point, I do not believe it is that bad.
  #8 (permalink)
Old 05-18-2008, 09:15 AM
Have not had time Saturday to yank the tranny back, and today {Sunday} looks like a rain out.
Hopefully get to it before long.
Uploaded a vid that shows that she will move, but got a damn noise that is just bugging me. Is this the noise that xlt4wd90 is speaking of??
Aerostar noise.wmv videos from friends & fun videos on webshots
  #9 (permalink)
Old 05-18-2008, 12:18 PM
Sorry, but I have never heard the noise myself, nor witness the problem personally, just a sad tale relayed to me by an old acquaintance. I hope your problem really isn't that bad.
  #10 (permalink)
Old 05-18-2008, 12:30 PM
I really dont think it is anything more than a loose shield. I'll keep you posted.
  #11 (permalink)
Old 05-28-2008, 05:15 PM
Update Upate Update!!!!
My son took the tranny cross member bolts loose and "straightened" the thing out, and no noise!! Go figure.
Also, if anyone is wondering, 170285 on the ODO when we did the "in frame" crank swap. She passed Delaware emissions with no probs, and she is back on the road!! Now I just gotta wash the thing.
  #12 (permalink)
Old 05-28-2008, 05:22 PM
DCRB is starting off with a positive reputation.
SWEEEEEEEEET!!! your aero looks just like mine, minus the rims.
__________________
93 3.0l xlt extended aerostar
mods:
800 watt sound system.
200+ farad kenetic battery + 875 cca reg. battery
2" catback exhaust w new flexpipe and cherry bomb muffler.
4g alt. wiring
Gutted stock airbox
2nd row bucket seats
'89 civic shell "PROJECT EF"
'89 civic donor car
  #13 (permalink)
Old 05-28-2008, 06:13 PM
must ride ruff with no rims!!
  #14 (permalink)
Old 05-28-2008, 09:12 PM
hahahaha you funny! lol i mean mine has alloys vs. your steely's. so what happened to your van, did you spin a rod bearing?
__________________
mods:
4g alt. wiring
Gutted stock airbox
'89 civic donor car
  #15 (permalink)
Old 05-29-2008, 03:06 AM
Yep. Got a brand new one off ebay for $90, and just put all new bearings in and closed her up.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
