Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 05:20 PM
twin66 is starting off with a positive reputation.
62 radio
Hello, I was going to post in the audio forum, but I figured here would be a quicker result. A couple months ago, i picked up a good straight AM radio from a 1962 F100. It will be going in my 66, as it never had a stock radio, and as far as I can tell, there are only 2 wire off the radio, a positive and a ground. Towards the rear of the radio on the same side as the wires, it looks like 2 holes for the round electrical connectors. Would those be for the radio? And if so, would the larger be the postive?
I wont be getting a speaker for this for a while, or powering it up, but would like to have everything ready for it.
Thanks, Craig
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-15-2008, 06:16 PM
jhooch's Avatar
jhooch is starting off with a positive reputation.
One hole will be for the antenna.
__________________
Jhooch
'05 Excursion Limited 4X4 6.0 Powerstroke
'77 Bronco 302, NP435
'76 F250 4X4 Crew 360, 4-sp (will be Powerstroke)
'66 F100 4X2 LB Custom Cab 428, C6
'66 F100 4X2 SWB Custom Cab, 352, 3sp.
'62 F100 4X2 LB Custom Cab Uni, 262, 4-sp
'64 Ford Galaxie 500 2dr HT
'63 Ford Galaxie 500 2dr HT
  #3 (permalink)
Old 05-15-2008, 06:38 PM
Right, forgot to mention, the antenna spot is on the opposite side, i will post a picture as soon as I get it loaded on the computer
Thanks
  #4 (permalink)
Old 05-16-2008, 01:29 AM
jhooch's Avatar
I'll see If I can get a pic of the backside of one of my radios. Both of my 66's and my '62 have their original radios. Actually my '77 Bronco has the same radio.
__________________
Jhooch
  #5 (permalink)
Old 05-16-2008, 06:28 AM
daveengelson's Avatar
daveengelson is gaining momentum as a positive member of FTE.
There is a single wire should have a fuse connector that connects to the yellow-black stripe wire in harness. The other 2 wires are for the speaker, the diag. indicates 1 is black, and the other is yellow-blk, but does not show which side is pos. or neg., since speaker wires not sure if it matters, perhaps more knowledgeable member can advise. On my 65 prior owner installed speakers in the metal door side panels so I removed cover plate on the back of radio and soldered leads for the speaker wires. Posting couple pic's of radio: One is a pic of fuse connector that connects to the wire harness. Another is a pic of the 2 hole connection for the speaker wires. In a perfect world the speaker will have the 2 pin connector attached. Finally, the other pic is of another type speaker connection consisting of male/female connector that will connect to corresponding mate, pic included. Hope of some help.
http://i300.photobucket.com/albums/n...IMG_0002-1.jpg
http://i300.photobucket.com/albums/n...IMG_0001-2.jpg
http://i300.photobucket.com/albums/n...s/IMG_0004.jpg
http://i300.photobucket.com/albums/n...IMG_0003-1.jpg
__________________
'problem with engaging in useless activity is never knowing when your done'
Last night I was looking at the stars and I wondered... where the hell's my ceiling!
65F100, 302ci, T18, swb, flareside,front disc. PS, Duraspark Ign.
65F100, 390ci, 3sp.OD, lwb, styleside, front disc., Duraspark Ign.
dave
  #6 (permalink)
Old 06-01-2008, 10:32 AM
Alright, slacker me has been busy, so here is a picture of the side of the radio. Now, there are no other connections on here except for a antennea spot on the other side, and a screw for adjusting max volume on the weakest station.
http://i33.photobucket.com/albums/d8...Picture001.jpg
Hopefully that works. If anybody has ideas, they will be appreciated.
Craig
  #7 (permalink)
Old 06-01-2008, 11:46 AM
Craig
Opps, failed to think by removing pic's from 'photo bucket' it would remove link to pic's, dah, anyhow, have since restored pic's. The pic is the connector for the speaker. As noted in the previous post, I removed radio panel and soldered wires to connect to speaker. There appear to be couple different type radio speaker connectors, they type you posted, and another type in pic's I posted.
Image of Ford Speaker connection - Photobucket - Video and Image Hosting **(Speaker Wire Connector)
Image of Ford Radio power cord connector - Photobucket - Video and Image Hosting**( Plastic connector for power source, and alternate connector for speaker)
Image of Ford power cord connector - Photobucket - Video and Image Hosting **(same connectors mentioned above)
Image of Ford Radio Power cord connector - Photobucket - Video and Image Hosting**(Speaker connector)
__________________
dave
  #8 (permalink)
Old 06-01-2008, 12:56 PM
So that would be the speaker connectors? Could i safely assume the big hole is positive? or is trial and error in play here? I have a couple old speakers i can try.
Thank you for the pictures though,
Craig
  #9 (permalink)
Old 06-02-2008, 06:05 AM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant future
61/66 radio antenna
The antenna mounts on the right side and has been reproduced by Dennis Carpenter.
The same antenna was used on all 1961/66 F100/1100's.
It's also the same antenna the 1961/64 Galaxies used: C3AZ-18813-C
There a hole pre-drilled in the right cowl inner panel specifically for the antenna cable to pass thru.
The only thing is, feeding that antenna cable thru that cowl hole can be a real PITA!
__________________
Bill / Retired Ford Partsman ~ 1962/97
Part number research: Trucks 1948/02 / Cars 1949/91
1963 Galaxie 500XL / 1965 F100 Styleside / 2008 Fusion
  #10 (permalink)
Old 06-02-2008, 10:32 AM
Not sure pos. or neg. wire connection matters. As noted, soldered leads in order to connect speakers installed in each door. Posting link to pics of 65 wire diag. but does not have diag. speaker internal wiring. Also posting link of pic's from 65 Ford shop manual, hopeful of some help. The manual includes page 3 which describes noise suppressant equipment, did not download the page.
http://i300.photobucket.com/albums/n...ioWireDiag.jpg
http://i300.photobucket.com/albums/n...kRadio0001.jpg
http://i300.photobucket.com/albums/n...kRadio0002.jpg
__________________
dave
  #11 (permalink)
Old 06-02-2008, 02:19 PM
BensDaddy's Avatar
BensDaddy is starting off with a positive reputation.
Just a side note: Where did you get the radio? I'm looking for one for my '64 F250.
__________________
The more I get to Know women, The more I like My Truck
If you ever reach total enlightenment while drinking beer, I bet you could shoot beer out of your nose. -Jack Handy
  #12 (permalink)
Old 06-02-2008, 02:42 PM
Ford Parts Guru
Quote:
The radio was used on a bunch of different vehicles.
Fits: 1961/66 F100/1100's / 1961/72 C/CT500/1100 (flat nosed Tilt Cabs).
Fits: 1966/77 Bronco
Fits: 1964/69 N/NT & T Series (the big trucks that use a 1961/66 cab and have unique front sheet metal..some have a conventional hood, some have a butterfly hood).
__________________
  #13 (permalink)
Old 06-02-2008, 06:32 PM
Well, looking at some pictures, its not the usual 61-66 radio, so this may be out of a car? NumberDummy may be able to help here, as the only numbers on it are: 24MF-169910. I will get a frontal picture of it up tonight.
Oh, and I bought it off Ebay for $25, and it was advertised a 62 pickup radio.
  #14 (permalink)
Old 06-02-2008, 06:58 PM
BensDaddy's Avatar
Thanks, I have to have atleast ten characters in my messages to post. Is this enough?
__________________
  #15 (permalink)
Old 06-02-2008, 10:26 PM
Ford Parts Guru
24MF-169910 is not a Ford # of any sort that I know of, how about providing a pic of the radio face.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
