Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 05:15 PM
Bobby82490 is starting off with a positive reputation.
Red face Freon
I dont usually hang out over here in this section.. mostly because i dont know hardly anything about A/C.
Now my truck's A/C doesnt seem to work as good as it did when i bought it. Its more "cool" now, than "cold" like it used to be when i bought it(1.5 yrs ago). Now with my truck being 10 yrs old im assuming that it has lost some of the freon from the system.. so im thinking about having the old freon and oil evacuated and new freon and oil put in.
I dont have current A/C vent temps, but im sure with a correct charge of new freon it would be colder than it is now... right?
__________________
-1998 F-150 5.4l auto 2wd, with a worn out 3.55 LS
-219,000+ miles w/ all orig. drivetrain
-No Muffler
  #2 (permalink)
Old 05-15-2008, 07:08 PM
lsrx101 is gaining momentum as a positive member of FTE.
Maybe, maybe not.
If the blend door isn't working properly it might not be as cool as it should be. You could have debris blocking airflow through the radiator/condenser. A bad fan clutch will cause poor cooling at idle or low speeds...the list goes on and on.
To properly diagnose the system you need the high and low side pressures at idle and about 1500 rpm. Knowing the model and year will also help.
__________________
Oh, you drive a Hummer? Isn't that just a cute little thing!! My ride is an EMD E-8A. Wanna play chicken!
www.lakeshorerailway.org
  #3 (permalink)
Old 05-16-2008, 04:42 AM
Its the truck in my sig.
This weekend maybe i will have it pressure tested, i will also check to see if stuff is in front of the condensor.
Also even at high speeds it is the same way, so that would rule out fan clutch(brand new) problem.
How would i check to see if the blend door is working properly.
__________________
-No Muffler
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
