Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 05:02 PM
BADBLUEOVAL351 is starting off with a positive reputation.
removed cat now have smoke please help
hello i need help cause im gettin nervous. i have a 2006 f 350 with a 6.0, ijust installed a turbo back exhaust and now once the engine temp starts coming up i get a lot of blueish gray smoke.if i leave a stop sign or traffic light it looks like i do a burnout. once the engine is at operating temp it mostly clears up but is still there a little when i take off after idling for even thirty seconds. i'm not using any fluids,no performance issues,the truck has 29000 on it. i tryed a bully dog tune on it but no change. i guess my next step is throw the cat back on and bring it to ford but im afraid the cat may mask the smoke. i didnt throw an engine light but maybe they can hook up and find a stored code so at least i have a direction to go. please help if anyone knows anything about this, cause i cant be the only one with this issue thanks.
__________________
Fresh Rides
06' F-350 PSD EC, Pro comp 2.5" coil spacer, 4 inch turbo back dual silverline pipes, recon smoked markers and mirror lenses, tinted windows, rhino liner, sirius, xtreme floor
93 Fox LX many mods-- gettin ready for 351w swap
Git-R-Done ------------ Got-R-Did
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-15-2008, 07:51 PM
StealmyTruck is starting off with a positive reputation.
So what's the problem again?
  #3 (permalink)
Old 05-15-2008, 08:23 PM
3000 FPS is starting off with a positive reputation.
The only thing I can think of would be the turbo. If the smoke is blue and gray in color and there is no smell of coolant at the exaust it would have to be oil that is burning. The Cat can hide a certain amount of this smoke but if it is as bad as you say then I would not think that it would hide it all. Try putting the cat back on and take it to the dealer if under warranty.
__________________
01 F250 4X4
05 F350 CC 4X4
Slammed 54 buick
  #4 (permalink)
Old 05-15-2008, 09:08 PM
Powerstroke_wannabe is gaining momentum as a positive member of FTE.
Sounds like you may have a bad shaft seal in the turbo.
__________________
Frank
2006 F250 Lariat FX4, CC, SB, 6.0 PSD, Torqshift, 3.73 LS, Backseat DVD system, Peragon Folding Bed Cover, Extreme Bedliner, Westin Bully Bar, Dieselsite Coolant Filter, Fumoto Valve, Accufab Intake Elbow, Bilstein HD Shocks, Smitty-Bilt Grille Inserts, MBRP Turbo Back Cool Duals, Kitty ran away
  #5 (permalink)
Old 05-16-2008, 06:57 PM
IA_FordBoy is starting off with a positive reputation.
When my kitty ran away the same thing happened...it is normal.
  #6 (permalink)
Old 05-17-2008, 03:45 PM
BPofMD's Avatar
BPofMD has a very good reputation on FTE.BPofMD has a very good reputation on FTE.BPofMD has a very good reputation on FTE.
Make sure Bully is out and disconnect both batteries for a short while so the codes clear.....Drive it a while after you do this. If they ask why you disconnected battery it's because you were gonna put in a new stereo system.
__________________
BPofMD
Maryland Asst. Chapter Leader
& PlankOwner
Bud
2005 F250 PSD 4X4 LB Arizona Beige
Join the Maryland Chapter click HERE
FORD ALL TRUCK NATIONALS
AUGUST 8--10, 2008 INFO HERE!
  #7 (permalink)
Old 05-18-2008, 05:05 AM
D8chumley's Avatar
Resident smarta$$
D8chumley is starting off with a positive reputation.
Quote:
Not really, mine doesn't blow ANY smoke at all, even at WOT. Kinda disappointing to have stacks that don't smoke, but with the price of fuel I can live with it for now
__________________
'04 F250KR CC FX4 6.0 swb,5" GrandRock Aussies,37" ProComp X-AT's,ccv & zoodad,RanchHand front,AM triple pod, DS coolant filter,Silverstars& some other stuff 130k
04 Explorer Limited
Tim
aka Rosie,Snowbunny for President
Go Flyers!
  #8 (permalink)
Old 05-18-2008, 12:31 PM
Have talked to a lot of people and like myself everyone is still baffled. The cat's goin on tomorrow and i'll see what happens. It's goin to ford soon for a tranny flush and some warranty stuff anyway so i'll have them check everything while it's there. I stood behind it the other day at idle while smoke was happening and without passing out i noticed the smoke has a total burnt smell no diesel,coolant,oil smell. Maybe everything is fine and the lack of a cat is the cause but that's crap in my mind, There's so many 6.0's out there that don't do this but my F*@%ing truck has to. I'll keep everyone up to speed with this thanks.
6 Liter
__________________
Fresh Rides
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
