Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 04:19 PM
ArdWrknTrk's Avatar
<--Dog is my Co-pilot
ArdWrknTrk has a very good reputation on FTE.ArdWrknTrk has a very good reputation on FTE.ArdWrknTrk has a very good reputation on FTE.ArdWrknTrk has a very good reputation on FTE.
Clutch release "chirping".......
..... and it's driving me insane!
I replaced my clutch just over a month ago. (well, my engine and clutch)
And for the past couple of days the release arm sounds like an angry locust when my foot is off the pedal.
I had lightly greased the "mushroom" pivot and "fork" with Moly while it was apart and I can see through the bellhousing that it's properly engaged in the throw-out bearing.
If I so much as touch the pedal it goes away. I thought this is what the spring in the slave is for. So, I changed the slave hoping it might help.
No luck..
Anyone encountered this before and have a *real* solution for me???
I'm think I'm going to lose my mind
__________________
Jim
'87 F-250 4V 460, T19, 4x4, 4.10 sterling 10.25" - Lil' Red
FTE Fraternity of Blue Max
  #2 (permalink)
Old 05-15-2008, 05:19 PM
uncle.stosh's Avatar
uncle.stosh is gaining momentum as a positive member of FTE.
It sounds like your throwout bearing is no good.
__________________
Quote:
Originally Posted by tommythomasson View Post
Priming with a drill - what kind of drill did you use? I'm not sure my DeWalt would turn the engine over...
  #3 (permalink)
Old 05-15-2008, 07:23 PM
Gorilla1 is gaining momentum as a positive member of FTE.
Uncle Stosh is right. Unless you replaced the whole shebang (aka clutch kit) the bearing is probably bad. Mines is hollerin like a mad banshi right now too. When my engine comes out (next big project) the whole mess will be replaced.
Rich
  #4 (permalink)
Old 05-15-2008, 07:35 PM
ArdWrknTrk's Avatar
Yeah,
I know.....
Even went so far as to purchase FORD release & pilot bearings because I didn't like the "Made In China" I saw on the ones that came w/ the Sachs clutch.
So I whipped those bearings in the dumpster.
I wish it was really rumbling or something critical, 'cause I'm not looking forward to pulling that tranny/transfer case.....again.
(at least the bellhousing bolts were chased and anti-sized a month ago )
slow
I *Did* replace everything, you can see here....
IMG_1903 on Flickr - Photo Sharing!
IMG_1905 on Flickr - Photo Sharing!
You'd be CRAZY to cut corners in here when you've gone this far.
__________________
Jim
  #5 (permalink)
Old 05-15-2008, 07:46 PM
81-F-150-Explorer is gaining momentum as a positive member of FTE.81-F-150-Explorer is gaining momentum as a positive member of FTE.
I agree, the throwout bearing is worn out.
If it was mechanical Clutch you could try and adjust the pedal free travel it should be 1/2 through 2-1/2 inches. If it's out of adjustment, it could cause the bearing to squeal. Or you could adjust it to compensate and stop a worn one from squealing for awhile.
Since it seems that you have a hydralic clutch though, a new throwout bearing is soon for your future.
Go the whole hog and buy a kit for it next time, if you didn't before, will save you grief like this in future.
Good Luck.
  #6 (permalink)
Old 05-15-2008, 07:57 PM
Hmm, well since you replaced everything, then it's either defective parts, or a clearence or adjustment problem. How was the bearing races, they could be worn etc...
  #7 (permalink)
Old 05-15-2008, 08:02 PM
ArdWrknTrk's Avatar
Races??
On the fork?
*edit*
I don't think there's any clearance, or adjustment with the hydraulic system. I thought that's why the slave has a spring inside. To keep the bearing engaged with the fingers on the pressure plate and constantly spinning.
Did you mean the races on the NEW release bearing???
__________________
Jim
  #8 (permalink)
Old 05-15-2008, 08:38 PM
Quote:
Sorry didn't put my thoughts to words very well there.
No, I meant on the old one. Was it scared up at all?
Then when you take the "new one" off you can inspect it and see if there is simular damage to the races of the bearing.
  #9 (permalink)
Old 05-15-2008, 08:50 PM
ArdWrknTrk's Avatar
I didn't have a clutch issue at all. I swapped the motor because @ 315k I finally spun a main, or rod bearing.
But there was no way I was going to put an 8 year old clutch back in behind a new engine.
__________________
Jim
  #10 (permalink)
Old 05-16-2008, 06:51 AM
Ken Blythen is starting off with a positive reputation.
If the throw-out bearing was failing, it would be making a noise when you put pressure ON the clutch pedal (causing it to revolve), but that is the opposite to what is happening. It sounds like there might be another issue.
  #11 (permalink)
Old 05-16-2008, 02:42 PM
mward69 is starting off with a positive reputation.
Quote:
I don't think thats the case, mine did it when my foot was off the pedal, I got used to driving with the foot on to stop that damn "chirping". New throw out took care of it {replaced everything}
  #12 (permalink)
Old 05-18-2008, 07:26 AM
Bern_F150_4x4 is starting off with a positive reputation.
Quote:
Ditto.....
__________________
'85 F150 4x4 300CID, NP435, 3.08's, Factory 15x8's, 31" Goodyears, Lock-Right in the back.
'86 F250 Supercab 4x4HD, 460 4V, T19, D50/Sterling 10.25 Trac-lok, 3.55's
FTE, yet another reason to have a networked PC in the garage!
The other side of green...
  #13 (permalink)
Old 05-18-2008, 07:52 PM
ArdWrknTrk's Avatar
Ok, what do you mean by {replaced everything}???
There's less than 800 miles on the clutch, new slave etc..
__________________
Jim
  #14 (permalink)
Old 05-18-2008, 08:48 PM
Personally I think you got a defective bearing. Or something caused the bearing to prematurely wear out in those 800 miles. Why I mentioned to inspect the races on the bearing when you remove it. If it's badly scared up, then I would look for a cause in why it is. Bad clutch fork, bad main bearing in tranny, or camshaft, causing wobbles, pilot bearings etc... something like that.
Don't want you to put in a new throwout bearing and in 800 more miles, have the same thing happen.
  #15 (permalink)
Old 05-18-2008, 09:06 PM
ArdWrknTrk's Avatar
I can see defective bearing,
But I;
Pulled the pto covers off the gearbox while I had it apart to see how things looked inside.
"camshaft"??
Pilot bearing is new in the re-man longblock.
The fork wasn't causing any problems before I swapped the engine.
Man, I really don't want to pull it down again..
I wish I could be sure it's not just the throwout spinning on the clutch fingers
__________________
Jim
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
