Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Ranger & B-Series
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 04:19 PM
massey0317 is starting off with a positive reputation.
better gas mileage?
I have a 07 ranger V6 and I am looking for ways to up my miles per gallon, any suggestions?
  #2 (permalink)
Old 05-15-2008, 04:25 PM
rubydist's Avatar
rubydist is gaining momentum as a positive member of FTE.
4.0 or 3.0? Stick or auto?
The 4.0 actually gets better mileage if you drive it a little harder - it will upshift too soon if you drive like grandpa, and below 2000 rpm that engine doesn't have much torque.
Keep it under 70, since the truck isn't particularly aerodynamic. Keep lots of air in the tires - as much as you can w/o having the tires wear funny. Put 0W30 synthetic oil in it at your next oil change.
__________________
06 Expy EB red/tan
03 Ranger FX4 white, factory buckets, stick, Saleen 17x9 w/ 275-60-17 Michelins, Eaton M90 supercharger (251 lb-ft & 217 hp @ wheels), Xcal2, JBA headers, Hushpower2 muffler, e-fan
94 SHO currant red/gray, atx
94 SHO performance white/gray, atx
93 SHO royal blue/gray, atx
  #3 (permalink)
Old 05-15-2008, 06:16 PM
hillbilly1025 is starting off with a positive reputation.
I understand the syn part but why the 0w30? sorry if thats a stupid ques
  #4 (permalink)
Old 05-15-2008, 10:25 PM
sfcwoodret is starting off with a positive reputation.
You will get pretty much what the truck is rated at with reasonable driving habits and there isn't much that can be changed about that.
__________________
2006 Ranger XLT
2007 Ford Escape XLT
2007 Ford Mustang Premium
  #5 (permalink)
Old 05-16-2008, 02:43 AM
oldgoat49 is starting off with a positive reputation.
I think that running the tires with some more air in them will help along with driving a little slower. However I wouldn't go to the max that is on the tire. I go more to a split between what is rec for the truck and the max for the tire. Too much air pressure will reduce the contact patch with the road which will reduce braking and in the rain will reduce grip. The Ow30 doesn't help except at startup. Once it is warmed up it is still up to the vis of 30 weight. On my 3.0 I am suppose to use 5w20, which is suppose to help with gas milage. I'd just try different driving styles and see which one seems to suit your truck better otherwise.
  #6 (permalink)
Old 05-17-2008, 10:02 AM
snowdog79 is starting off with a positive reputation.
Put a vacuum guage in it. You see just what your right foot is doing, and how much it's costing you. You can usually use smaller throttle openings and still maintain your speed. I play the "how many MPGs can I get" game with all my vehicles. It's fun and keeps my money in my pocket instead of Chevron's.
__________________
Current Ford Trucks
00 Ranger SC 4x4/4.0/a
07 F150 Screw 4x4/5.4
Previous
69 F600 300/5+2
77 F250 4x2/351M/C6
78 F150 SC 4x2/300/3M
79 F150 4x4/400/T18
85 Bronco II XLT 4x4/2.8/a
89 F150 4x4/300/4M
93 EB Bronco 5.0
00 F150 7700 SC 4x4/5.4
01 F350 CC 4x4 DRW PSD
03 Explorer 4.6/AWD/LS
  #7 (permalink)
Old 05-17-2008, 10:19 AM
rubydist's Avatar
Quote:
Not a stupid question at all, since many people don't understand how oil is categorized.
XW30 oil is all virtually the same viscosity at 100 C, which is roughly the temperature that the oil runs at once the engine is warmed up.
0Wxx oil is less viscous than 5Wxx oil when measured at 0 C.
So, the 0Wxx oil will be less thick during the engine's warm-up phase. This has 2 significant advantages. First, the vast majority of engine wear occurs when the engine is cold (well documented by scientific studies), and a less thick oil results in less wear when the engine is cold. Second, the oil that isn't as thick when cold will have lower pumping losses, so the engine is more efficient and returns slightly better mileage.
__________________
06 Expy EB red/tan
  #8 (permalink)
Old 05-17-2008, 11:18 PM
bazzman1953's Avatar
bazzman1953 is starting off with a positive reputation.
here
This should answer some of your questions.
__________________
'94 Mazda B4000 SE 4.0L 4x4 M5OD X-cab
"YOU DON'T NEED A BLOODY CHERRYPICKER TO GET THINGS OUT OF THE BED"
  #9 (permalink)
Old 05-18-2008, 06:41 PM
whitebassbenny is starting off with a positive reputation.
I can't get better then 14 city in mine driving under 2K at all lights and at around 55 on HW i get about 20-22.
__________________
94 ranger 4x4 auto
138,000
31x10.5x15
intake
T-cover
had cherry bomb turbo muffler, flowmaster series 40 (used about 2-3 months make offer clampped on) now cherry glasspack.
2x55w offroad lights in grill
CD with 4 new speakers
500 watt sub w/1500watt amp (has alotta bump in back of seat.)
Tints %20 front %5 back
  #10 (permalink)
Old 05-18-2008, 07:30 PM
billj6 is starting off with a positive reputation.
3.0 liter mileage
Whitebass, you must have the 3.0 also. About 14 city and just under 22 highway is what I have always gotten in my '99 x-cab, 2x4. It now has 95,000 miles and I just punched some very small holes in the paper air filter as an experiment. Haven't clocked mileage since but it still runs like a watch. I recently changed AT fluid for the first time ever and I think that contributes to my feeling of well being. Next long drive I'll watch mileage. Usually I just drive to work and back - 28 mi. r/t. In 1998 I had a Toyota Tacoma 4 cylinder with 5 speed stick. Didn't stop at gas stations nearly as often then and it had guts too. Love my Ranger, but gas mileage is the biggest disappointment. I said that even when gas was much cheaper.
  #11 (permalink)
Old 05-18-2008, 09:07 PM
scottm is starting off with a positive reputation.
Bazzman meant to say: http://www.ford-trucks.com/forums/73...about-gas.html
  #12 (permalink)
Old 05-18-2008, 09:54 PM
Thanks, scottm, my link was a dead click.
I pulled 22.5mpg last week 30%city and 70%hwy in hilly country fighting strong headwinds climbing up out of Marquette back to Ishpeming for two days. Not too bad for a truck with 180.xxxmi. on it and a front end needing repairs and a non-existant rear shackle bracket.
It has a bad MAf sensor, also.
Shows what can be done by connecting the graymatter to the truck.
__________________
  #13 (permalink)
Old 05-18-2008, 10:31 PM
Since I didnt see the stock answers for helping mileage, here goes:
Tune up. New wires and plugs if they arent new already.
Airfilter. Low restriction, either a new paper one or a KN filter. If an FIPK gets you from 20 to 22 mpg, it'll pay for itself in 10,000 or so miles, not counting what it'd cost to replace 3 paper filters in that time. (assuming gas at 4$/gal, and you can keep your foot out it...)
Exhaust, again, another couple MPG can be gained there.
Drive slow, accelerate slowly, decel slowly, don't idle if you can help it, and tailgate semi's.
Or, move to the not so great white north like bazzman, where the air is always cold and dense :-p
Scott
  #14 (permalink)
Old 05-19-2008, 12:08 AM
Sponsor
Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.
Any money you save on a K&N gets eaten up when it destroys the MAF sensor. IF you want a washable filter, go for the AFE ProDry. I switched from K&N to ProDry, and I'm never going back.
__________________
My Rides
1994 Ford Aerostar 4.0L AWD extended
175,000 miles
Fullblown 50 series catback system
590 watt sound system
1990 Mazda B2600i
505,000 miles
Custom exhaust with BearCats high flow converter and a straight through muffler
Custom high velocity intake with AFE ProDry filter
  #15 (permalink)
Old 05-19-2008, 09:31 PM
I will NEVER put another K&N on my truck. My MAF sensor is ruined because of one [installed before I got the truck]. They are not cheap to replace.
Anyhow... more ways to increase mpg, kick the air pressure in your tires to 42psi is a good comprimise, TIMEING LIGHTS... make this one a video game that you are out to win by not stepping on your brakes [-points for touching them]. Learn your route and how to antisipate traffic patterns. Adjust your driving accordingly, remember, every time you touch your brakes you loose points, and the harder you hit your brakes the more points and MPG!!! you lose. When you start to turn this into a game your ride will become more interesting and more challenging. You are now competing against OPEC and yourself.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
