Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1997 - 2003 F150 97-03 F-150, 97-99 F250LD, 7700 & 04 F-150 Heritage
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 03:48 PM
ford2002f150 is starting off with a positive reputation.
starter relay
hey, im back again. having all sorts of problems.
anyways, i did a long a drive today. pull over for some gas after only about 200 miles. after im done, i go to start my truck (02 f150 v6), and nothing happens. no clicking no nothing. hoping its just the battery i ask some guy to give me a jump. nothing happens. no clicking no nothing. so some other guy comes over and takes a screwdriver, connects two terminals, and the truck starts up as if nothing was wrong. the guy said "hey your battery is fine. your starter is fine. sometimes you just lose connection. this is just another way to crank the motor. you got no worries." well i make it to where im going and the truck has been starting up no problem since then.
now im reading through some haynes manual about starters and after scrolling down i see... "If the starter motor still doesn't operate, bridge the two large terminals on the relay with a screwdriver. If the starter now works, replace the relay." but it doesnt say much else like why this happened or whats wrong with the relay or anything.
so... is this something that i should worry about? or if i just carry a screwdriver with me from now ill be fine?
thanks a bunch!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-15-2008, 04:13 PM
Bobby82490 is starting off with a positive reputation.
Sounds like you need to replace the solonoid(relay) on the firewall.
__________________
-1998 F-150 5.4l auto 2wd, with a worn out 3.55 LS
-219,000+ miles w/ all orig. drivetrain
-No Muffler
  #3 (permalink)
Old 05-15-2008, 04:37 PM
KingRanchMan02's Avatar
KY KR lover
KingRanchMan02 is gaining momentum as a positive member of FTE.
You need to replace the relay most likely. The starter relay has three wires. One is from the battery(red), one to the starter (red), and the other(tan/red) is from a fuse (hot in start, F21) in the central junction box via the digital transmission range sensor. If you have no voltage out to the starter then check to insure that the tan/red wire is hot in start. If not, then troubleshoot back to the fuse and the DTR sensor. If this is good and there is no voltage on the red wire to the starter then replace the starter relay.
Good luck!
__________________
John
aka KingRanchMan02
`02 F-150 King Ranch SuperCab
Charcoal Blue/Arizona Biege
5.4L 3.55 LS, 4x2
Diablosport Predator Programmer, K&N filter.
  #4 (permalink)
Old 05-15-2008, 06:03 PM
projectSHO89 is gaining momentum as a positive member of FTE.projectSHO89 is gaining momentum as a positive member of FTE.
I don't think a screwdriver can jumper the two big terminals - that takes a large pair of pliers.
If it was only a screwdriver, he probably jumpered the HOT to the S terminal of the relay. If so, you have a problem in the small wire circuit that KRM talked about (key switch, CPP/DTR, etc).
Advise if there is an aftermarket starter interrupt or alarm installed...
Steve
__________________
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
