Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 03:42 PM
fishel74 is starting off with a positive reputation.
cab light not coming on with door open
Guys,
I asked this question once before and i did what everyone told me to do but it didn't help. I have a 2002 SD extend cab. When you open the doors, my interior light does not come on. If you flip the switch on the dash to manually turn it on, it will come on. But simply opening the drivers door or passengers door it will not turn the light on. Does anyone have any ideas? Is there a sensor to clean or replace. I doubt it is a fuse being the everything else works. The truck has done this since February when i got it.
Thanks
  #2 (permalink)
Old 05-15-2008, 05:56 PM
high ho silver's Avatar
high ho silver is starting off with a positive reputation.
Just what was it that you did before that did not work based on suggestions from others? Was it the WD-40 all over the latch trick? If not, try it. Has it always done this or did it just start. I don't know the history of your truck but if you bought it used, someone may have reset something. Check your owner manual and see if there is a process to turn this feature off / on.
__________________
2000 F250 SD ext. cab 4 X4, 5.4L, 4.10LS
  #3 (permalink)
Old 05-15-2008, 08:23 PM
msgtg's Avatar
msgtg has a great reputation on FTE.msgtg has a great reputation on FTE.msgtg has a great reputation on FTE.msgtg has a great reputation on FTE.
Usually spraying the lock heavily with WD-40 makes the difference. I've not heard of any other issues with a sticking light switch.
Joe
__________________
MSgtG
Chapter Leader - West Virginia
Club SNL # 30
JOIN THE WEST VIRGINIA CHAPTER CLICK HERE
92 F150 351 XLT SC 8'
03 F250 6.0 King Ranch Crew 4 X 4
01 Taurus SES Wagon - hers
We are the land of the free BECAUSE of the brave!
Thanks to all Vets, past, present, and future
  #4 (permalink)
Old 05-16-2008, 07:12 AM
When i bought the truck (Feb 2008) the light did not work properly. It still is not working properly. I tried spraying contact cleaner into the locking mechanisim when the door was open. Should I try spraying WD-40 in the keyhole? I will also try it on the locking mechanism being that i tried contact cleaner the first time. The condition happens with both the drivers and passenger doors. I will try them both. Is the light switch in the locking mechanisim or is there a seperate switch somewhere like the older fords had that depresses against the cab when the door is shut?
  #5 (permalink)
Old 05-16-2008, 04:15 PM
msgtg's Avatar
I BELIEVE it's integrated into the locking mechanism...it's not an old style contact switch like we're used to seeing.
I recommend you try using the WD vs the contact cleaner...I think this is a lubrication issue vs a dirt issue.
Let me know how that goes.
Joe
__________________
MSgtG
Club SNL # 30
  #6 (permalink)
Old 05-16-2008, 07:09 PM
luthrobediesel is starting off with a positive reputation.
do the bigger trucks have general time modules like my ranger. Cause my lights wouldnt work or the wipers or the chimes. i unplugged the GTM and plugged it back in and everythings fine
  #7 (permalink)
Old 05-16-2008, 11:39 PM
mind is starting off with a positive reputation.
When i bought my truck the previous owner or place i bought it from had one of the relays in the wrong place, maybe on purpose to get rid of the door chime.
  #8 (permalink)
Old 05-18-2008, 12:53 AM
Cass is starting off with a positive reputation.
Not that I am advocating not being safe, but if you just want to get rid of the door chime, go to the dealer and ask for a seat belt extension. You connect it and it thinks that you are using the seat belt and no more chiming.
  #9 (permalink)
Old 05-19-2008, 10:17 AM
Beerstalker's Avatar
Beerstalker has a good reputation on FTE.Beerstalker has a good reputation on FTE.Beerstalker has a good reputation on FTE.
There are better/safer ways to get rid of the seatbelt chime. Check your Owner's guide, or look in the Tech Folder for the link to a thread on disabling the different chimes/dingers.
__________________
2007 F350 Lariat, CC, LB, 4x4
4.5" DR Lift w/35x12.5r20 Toyo Open Country M/Ts
Keystone Restyling Ram Air Hood W/Airaid Intake & Pre-filter
Recon Smoked Cab, Mirror, and Brake Lights
MSD Dashhawk w/A Pillar Mount
Dieselsite Coolant Filter
Lund Eclipse Window Vents
Weatherguard Toolbox
  #10 (permalink)
Old 05-23-2008, 01:58 PM
ColoradoKid07 is starting off with a positive reputation.
Question Interior Cab Light Not Coming On When Door Is Opened II
I have a '99 Superduty Ext. Cab. that I just bought two days ago. My interior cab light does not come on when any doors are opened. Plus, it does not come on when the dimmer switch is rolled all the way up as it's supposed to do. I've checked for continuity thru the bulb, of which there is, so that tells me the bulb is good. Are the switches for this light on the front of the half-doors just above the handle that opens the half-doors? Is that what is supposed to be sprayed? Or is it the door lock cylinder where the key is inserted? I've checked fuses, and can't seem to find any that are blown. Both of the map lights on either side of the cab light DO work. Thanks in advance for the suggestions! I appreciate it! Dan..................
  #11 (permalink)
Old 05-23-2008, 08:34 PM
msgtg's Avatar
Yes, spray the door locks...but I'd recommend you shoot a little in the door lock cylinders too.
Joe
__________________
MSgtG
Club SNL # 30
  #12 (permalink)
Old 05-24-2008, 05:27 AM
Budman1962 is new and has a neutral reputation at this point.
There is a sensor at the bottom of the latch that tells the computer if the door is open or closed. Its the wire closest to his palm in the pic. Usually if they get dirty the light stays on when the door is shut. I think you have a fuse or relay problem.
__________________
When the drive is through this Buds for you!
2000 F-250 V-10 SWB CC
  #13 (permalink)
Old 05-24-2008, 07:48 AM
So is this latch assembly that is shown in the picture in the main door, or the half door? Thanks!
  #14 (permalink)
Old 05-24-2008, 10:40 AM
Main door. If you need to take them out this link will help although its for lock actuator replacement. Try to find out which relay controls the lights that would be the first place to look.
2000 Ford Excursion 4x4 - Door Lock Actuator Installation
__________________
  #15 (permalink)
Old 05-28-2008, 08:36 PM
If the cab light isnt coming on when you roll the dimmer switch all the way up your problem isn't the door switch. If you roll the dimmer switch all the way up do the cargo lights in the bed come on?
Have you tried checling for 12volts at the light socket instead of checking the light for continuity?
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
