Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Ranger & B-Series
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 01:24 PM
mahause is starting off with a positive reputation.
Gas Gauge stuck on full
This week my gas gauge is stuck on full. If I remove power it goes to 3/4 tank. About three months ago it was stuck on empty until I swapped out the float and it worked fine until now. I gather from previous threads that the fuel sending unit is probably the culprit.
I should test this by disconnecting the conection to the fuel sending unit and shorting the white or yellow cable to ground. If it reads empty then the fuel sending unit is bad. If it remains on full then the gauge is bad or the cable is disconnected somewhere in between.
Does this sound like the right course of action?
The truck is a 1997 2.3L 5 speed Regular cab.
Thanks in advance for any advise.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-15-2008, 04:35 PM
87 XLT is starting off with a positive reputation.
The specs that i find are 145 ohms from the sender equals full tank.
22 ohms equals an empty tank.
So, yes if you ground the yellow/white stripe it should read empty.
  #3 (permalink)
Old 05-19-2008, 10:02 AM
I was able to get the gauge to read empty by putting a jumper between ground and the yellow wire. After removing the sending unit I plugged it in and the gauge worked when I moved the float arm. I reinstalled it and everything is working fine. I think the float was stuck and was dreed when I pulled it from the tank. Thanks for the reply.
  #4 (permalink)
Old 05-19-2008, 10:34 AM
Good deal, glad you got it squared away.
  #5 (permalink)
Old 05-19-2008, 01:43 PM
michigan66 is starting off with a positive reputation.
Gee, I wish my gage would stay on full. At 4 bucks a gallon, its getting expensive to get back to the full mark.
__________________
1991 XLT, 2.3 SOHC, 5 sp. manual,
3.45 7.5" open axle, Synthetics in Engine, Trans., Diff.
225/70 x 14 Bridgestone Dueler APT III tires,
85 K miles., std. cab, long bed, fiberglass topper
2008 Mercury Milan
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
