Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 01:12 PM
LARIAT 85 is starting off with a positive reputation.
How Much More Power Can an AOD Take?
1985 Ford F150 Lariat
Carbed 302 engine, AOD tranny
3.55 rear
I have a basically stock 302 motor, only it now has a 4-barrel setup, and of course the Duraspark II ignition conversion. What I plan to do is port and polish the stock E5 heads, and upgrade to a more efficient camshaft (nothing radical). And last would be a set of long tube tri-Y headers.
That is what I would like to do. The question is, can my newly rebuilt AOD handle the changes?
  #2 (permalink)
Old 05-15-2008, 02:58 PM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
I say yes, I'd suggest you add a shift kit if you haven't already. My 357 produces more TQ than a 302 could ever hope to muster and my AOD is going on 8 years and counting.
__________________
Paul O
1990 F150 4x4 XLT Extended Cab 5.9(351 .030" over), FMS SEFI MAF Kit, Ported E6s, Crane 444232,
AOD, TransGo Shift Kit, 3:55LS, Flowtech Longtubes, TweecerRT
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08
  #3 (permalink)
Old 05-15-2008, 03:09 PM
85e150six4mtod has a good reputation on FTE.85e150six4mtod has a good reputation on FTE.
Look at the mods listed here.
There are some weak areas in the AOD, if you fix those you will get the longer life.
AOD Transmission from PATC, AOD Transmissions
AOD Performance Products - Baumann Electronic Controls
www.CKPerformance.com
TCI - Ford AOD, AODE and 4R70W
Note one or more state they use '88 to '93 cores as there was some change made in '88.
Good luck.
BTW, I hope you fixed up your TV cable or linkage when you swapped to the 4v. Leading cause of heartbreak is improper throttle valve adjustment. Burn 'em up quick.
  #4 (permalink)
Old 05-15-2008, 05:15 PM
Why would you suggest a shift kit? I don't plan on racing it or anything like that. What would the benefits be to using a shift kit?
By the way, I also heard how important an axillary tranny cooler is to the AOD. I just bought a stock Ford AOD transmission cooler, and am trying to figure out where to mount it. Where is the stock location points for the tranny cooler on '80-'86 F150s? Anything I should know before I install it?
TV cable adjustment is already covered. I had a friend who rebuilds transmissions for a living adjust it for me. He also warned me how CRITICAL the adjustment is. I have been running the 4V for about a year now without any problems so far.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
