Quote:
I say yes, I'd suggest you add a shift kit if you haven't already. My 357 produces more TQ than a 302 could ever hope to muster and my AOD is going on 8 years and counting.
Why would you suggest a shift kit? I don't plan on racing it or anything like that. What would the benefits be to using a shift kit?
By the way, I also heard how important an axillary tranny cooler is to the AOD. I just bought a stock Ford AOD transmission cooler, and am trying to figure out where to mount it. Where is the stock location points for the tranny cooler on '80-'86 F150s? Anything I should know before I install it?
Quote:
BTW, I hope you fixed up your TV cable or linkage when you swapped to the 4v. Leading cause of heartbreak is improper throttle valve adjustment. Burn 'em up quick.
TV cable adjustment is already covered. I had a friend who rebuilds transmissions for a living adjust it for me. He also warned me how CRITICAL the adjustment is. I have been running the 4V for about a year now without any problems so far.
