Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Ranger & B-Series
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 01:06 PM
Zipper43 is starting off with a positive reputation.
External Coolant Leak
Hey Folks;
I'm new here and am hoping someone might be familiar with my problem. I have a 99 Ranger XLT 4X4 with the 4.0L V6.
For a while now I've been noticing the smell of coolant when I get out of my truck after driving it and had been having to top up the coolant every once in a while but couldn't tell where the leak was coming from.
Over the last couple of days the leak has become a steady stream that results in a pool of coolant under the truck after parking it. The leak stops shortly after the truck is turned off.
I checked the hoses and the water pump They all seem fine. I got underneath my truck last night and the leak appears to be coming off the left (drivers) side of the engine block. I think it might be a drain plug or something similar, but the haynes manual I have doesn't seem to cover sources of coolant leaks that aren't either the water pump or a hose.
Can anyone help?
Regards
Jim
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-15-2008, 02:05 PM
Aggie05 is starting off with a positive reputation.
NOt to familiar with that model but i have had to trace these in the past. I had luck with grabbing some break cleaner and spraying down where you think its coming from then playing the waiting game. You can also top off the system with water / coolant drive it around heat it up and then shut it off. WHen you turn the engine off it tends to build up pressure for a bit until it cools and thats a good time to start the hunt.
Im sure someone here can give you better ideas as where to look.
Goodluck!
__________________
92 Ranger 2.3 ltr stick shift.
03 Nissan 350z
  #3 (permalink)
Old 05-15-2008, 04:13 PM
bamabacker is starting off with a positive reputation.
I would check along the plastic tubes on the sides of the radiator after I checked the hoses and the drain plug (don't tighten that plug too much - hand tight is usually good enough). It is common for these plastic tubes to develop cracks over time, especially on the inlet hose side (top hose). Often, you will not see these cracks but you will see AF dripping down from the top half of the radiator on the sides. If this is the case and you have to pull the radiator (it's really an easy job), consider having the tube and gasket replaced and the radiator rodded out and cleaned vs. buying a new one. I just did this to mine and it cost about $115. A new radiator will cost about double. Radiator.com is a hard place to beat if you purchase a new one. Hope this helps!
  #4 (permalink)
Old 05-16-2008, 09:45 AM
Sponsor
Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.
One of the best ways to find leaks like that is to get a pressure tester, so you can see what the system would behaive like when it is hot, without the heat. I think you can also get a fluorescent dye to add to the antifreeze. They you just look around there with a blacklight, and the leak should become apparent.
__________________
My Rides
1994 Ford Aerostar 4.0L AWD extended
175,000 miles
Fullblown 50 series catback system
590 watt sound system
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
Custom exhaust with BearCats high flow converter and a straight through muffler
Custom high velocity intake with AFE ProDryS filter
http://www.bearriverconverters.com
  #5 (permalink)
Old 05-19-2008, 11:36 AM
Hey Zipper,
Ever find where your coolant leak was coming from?
  #6 (permalink)
Old 05-23-2008, 03:18 PM
Hey bama;
Found it alright. Turned out to be coming from the lower intake manifold. Wasn't difficult to find after the gasket blew out completely on my way home from work. Replaced the gaskets and all seems fine now.
  #7 (permalink)
Old 05-23-2008, 05:31 PM
Good deal! Was it a hard job, and can you go into a little detail as to what you had to do to fix it? Thanks.
  #8 (permalink)
Old 05-26-2008, 09:56 PM
cooljman1 is starting off with a positive reputation.
I had the same lower gasket coolent leak on my truck some years back.
__________________
early '99 F250 7.3L 4X2 Stock for now
'94 Ranger 4.0L 4X4 Lots of mods.
'06 Mariner 3.0L 4WD Stock
  #9 (permalink)
Old 06-09-2008, 06:39 PM
RangerRuss is starting off with a positive reputation.
Not a hard job just tedious.
Russ
__________________
2002 XL 2.3 Automatic
1998 Contour Zetec 2.0
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
