Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 12:54 PM
Sanchez_315er is starting off with a positive reputation.
V/B F250 Springs without the lift...
I did some searches, but couldn't find any info on this. Is it possible to swap in V/B springs and not gain any lift? I would like the extra capacity, but have no need for extra height, and would appreciate the handling advantages of the lower center of gravity.
__________________
04 Excursion 4x4 EB V10 3.73s
Rockwood 8317SS Travel Trailer
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-15-2008, 01:06 PM
OK, OK, so I'm a
housedad is starting off with a positive reputation.
In a word, no. The V code springs by their nature will lift the front of a v-10 by at least 1.5 inches.
The original object of those of us who figured out what works best in the spring swap was not additional capacity, but rather to get the front springs away from the frame stops (bumpers).
After a little while, the original front springs of a Excursion sag. There is not a lot of room to begin with between the spring and the bumper, and it is even worse with the Diesels. After the sag, you find 1 to 1.5 inches of travel left on the springs, and this makes a very harsh ride. The diesels would many times have no room at all, and the spring would be on the frame stops at all times.
Changing to a slightly higher capacity and greater arched spring from the Superduty line addressed this problem, and cured it very well.
The B code (or F code) rear springs and blocks addressed the soft rear spring system and the heavy sagging when hauling people, or a trailer. It also brought the lift up to be even with the 1.75 inch rise in the front.
The only way to improve the ride is to raise it. It does not have to be much, like with V's and B's, but you have to get room between the axle and the frame to provide spring travel.
Bion Rogers
__________________
2005 EXCURSION!! XLT V10 Silver Heated trailer mirrors, Hood/window deflector, Firestone airbags/onboard air, Helwig swaybar, Prodigy, underhood liner and light, V's and Modded B's, Bilsteins, Procomp stabilizer, Curt front reciever, 6 disk Visteon stereo, 6 disk changer console, X-3 AIC. 4.30 axles
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
