Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 11:21 AM
dukedrummer89 is starting off with a positive reputation.
Got an e4od ? (Lookin at a 1996 f150)
I went to look at this truck last night, its a 96 f150 4x4,160k, XL, 300-6, e4od, reg cab longbed. Anyway, the lady only wants 500 bucks for it, it runs flawless, the interior is spotless, and the body is in good shape, no dents, usually ford rust.
Anyway, she said the tranny was shifting real hard, she had her neighbor replace the filter on the tranny, thinkin it was bad. When he dropped the pan, a couple lil balls fell out. (thats what she told me) anyway... what do you gurus think is wrong with it? Perhaps i could swap valve bodiies? I have an good e4od out of a 92 sitting in the garage, along with a mound of other ford parts, i was thinkin about swappin out the trannys, maybee makin a lil money.
Thoughts???
__________________
1993 Lightning... K+N, strait pipes, down 2in, "euro's", 20k miles, daily driver
2006 Yamaha R6/S 5400mi all black
1996 f150 300-6 e4od 4x4 "Baby Blue"
1992 F150/Bronco "The 84" (Hunk of junk sittin on 40's)
Quote:
Originally Posted by nhill2090 View Post
Don't buy a K&N, its bad for your motor
  #2 (permalink)
Old 05-15-2008, 12:01 PM
quicklook2's Avatar
quicklook2 has a good reputation on FTE.quicklook2 has a good reputation on FTE.quicklook2 has a good reputation on FTE.
it is missing its balls.
buy it for 500 and then figure out what is wrong.
probably the valve body, the neighbor might not have known what he was doing and messed it up.
it is a steal for a 4x4.
i will buy it if you do not.
__________________
"The essence of knowledge is, having it, to apply it; not having it, to confess your ignorance." ~Confucius
  #3 (permalink)
Old 05-15-2008, 12:18 PM
yea, after i take the 89 f250 to the scrap, ill probably get it.
do you think i could just swap out the valve body off the tranny ive got? would a 92 adn 96 e4od interchange?
__________________
  #4 (permalink)
Old 05-15-2008, 02:07 PM
Virto is gaining momentum as a positive member of FTE.
The 96 tranny has better components than the 92.
You'd be best off either swapping in your good tranny or rebuilding the 96 with the correct parts. Your 92 tranny can be built to later spec using the revised parts, so yes, they will interchange...but the later the E4OD parts you use, the better off you will be.
4x4 for 500 bucks? Around me it would have no engine in it. Snatch that one up.
__________________
Join us in fighting disease! Fold for FTE team 53449!
Quote:
Originally Posted by Silver Streak View Post
You're having problems because some butthole put the wrong one on your truck.
1990 Ford F-150 XLT Lariat Supercab - 5.0/E4OD - Off to that big wreckers in the sky...*sniff*
1993 Ford F-150 XLT Supercab - 5.0/AOD - 3.55
  #5 (permalink)
Old 05-15-2008, 02:31 PM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
Actually.. I bet there's nothing wrong with the tranny. If the pan has never been off it there will be at least 1 curious looking round piece in there, this is a plug installed in the oil fill tube on the assembly line to prevent dirt getting in the tranny, this plug gets pushed into the pan when fluid is added for the first time.
Hard shifting with the E4OD equipped trucks often indicates a bad VSS, it's common to see an eratic or dead speedo at the same time. The computer defaults to a firm shift pattern when is looses the VSS signal as a protective feature for the tranny.
__________________
Paul O
1990 F150 4x4 XLT Extended Cab 5.9(351 .030" over), FMS SEFI MAF Kit, Ported E6s, Crane 444232,
AOD, TransGo Shift Kit, 3:55LS, Flowtech Longtubes, TweecerRT
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08
  #6 (permalink)
Old 05-15-2008, 02:42 PM
quicklook2's Avatar
i was going to mention the plastic piece but the guy said small balls so i thought maybe something else.
it may be the vss but this truck sounds well worth it to me.
__________________
  #7 (permalink)
Old 05-15-2008, 02:44 PM
Thanks, that info is really helpful...
Ill probably be pickin in up soon, even tho this will make truck number 4 at one time, i think its worth it, except for the nasty baby blue/purple the color is, its probablly still a deal.
Im half temped to turn it into a daily driver, with gas being 4 bucks a gallon, insurance would be cheaper, and id like to keep the miles off of my lightning.
Worse case scenario, what would a e4od rebuild cost, if i pulled it myself and took it in? What would a TQ cost roughly? i know the e4od arnt cheap
Oh, and what do the stock 300-6's get for mpg's, around 18 or so?
Thanks again
Chris
__________________
  #8 (permalink)
Old 05-15-2008, 03:01 PM
quicklook2's Avatar
around 15 is more like it, if that in he city.
if you need a some info on the valve body i have the ford service manuals.
i am on vacation around the 18th until the end of the month and will not be on here as much.
__________________
  #9 (permalink)
Old 05-15-2008, 03:15 PM
well, thanks for the help
hopefully ill get it this weekend, this truck will be lucky #10, my 7th f150
__________________
  #10 (permalink)
Old 05-16-2008, 09:50 PM
icrman is starting off with a positive reputation.
Maybe someone was being funny and put those balls down the dipstick tube.
__________________
1996 F-250, XLT 460 E4OD, Long box, Supercab 4X4, 4.10 Axle Ratio, Camper and tow package.
Self install of: Clifford alarm, B&W Flipover gooseneck hitch, Ride Rite airbags, and compressor system, Prodigy Brake controller.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
