Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 10:21 AM
mrfixit290 is starting off with a positive reputation.
HOT Caliper
Hi guys I was washing my truck in front of the house after i drove home from work.(6 miles) When water got on the right rear caliper it started to steam. I was told that the caliper is sticking and it need to be replaced. I have not had truck checked out yet I wanted to know how could I check the caliper to see whats wrong. Thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-15-2008, 10:24 AM
Professional Know-It-All
RACERX7775 is starting off with a positive reputation.
is that the only one that did it? its normal for you brakes to get very hot. i mean, they are stopping 8000lbs going 60 mph over and over again.
__________________
01 EXCURSION LIMITED, 4X4, V10, 22" CHROME WHEELS, LOTS OF CHROME, LOTS OF TVs, 06 FRONT END CONVERSION, LIGHT BAR WITH 6" HID LIGHTS
  #3 (permalink)
Old 05-15-2008, 10:38 AM
Yes the right rear is the only one that was that hot
  #4 (permalink)
Old 05-15-2008, 10:54 AM
whjco is starting off with a positive reputation.
Be sure and check your pads and rotor thickness/warpage as a sticking caliper can affect this as well.
__________________
Bill J., Lexington, KY
  #5 (permalink)
Old 05-15-2008, 11:52 AM
betontheturtle is starting off with a positive reputation.
I would pull the caliper and regrease the the slide pins first , see if that fixes the problem. If not, yeah replace the caliper. Depending on how long its been sticking you may need to replace pads.
  #6 (permalink)
Old 05-15-2008, 01:13 PM
mohrds is starting off with a positive reputation.
Quote:
Ditto on checking the pads. The rears aren't as likely to warp the rotor from a stuck caliper, but it can happen.
A good rule of thumb is every time you rotate your tires, clean and regrease the sliders. The 10 minutes per wheel extra time will save you hundreds of dollars in brake parts later.
This is one of the reasons I HATE sliding calipers. Give me a good set of fixed calipers and I'd be a happy guy. Too bad there isn't a replacement kit for the Ex
Doug
__________________
2000 Excursion Limited 4X4
V-10, 90,000 miles
2008 Tow Mirrors, 2007 F-450 front end, Blistein shocks, Draw-Tite front receiver.
  #7 (permalink)
Old 05-15-2008, 09:46 PM
what do I use to regrease the caliper with
  #8 (permalink)
Old 05-16-2008, 02:53 PM
silicone high temp brake grease. available at most auto parts stores , a little goes a long way.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
