You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
should be, they had dozens signed on until the switched locations.Found out what broke drivers wheel bearing took a crap and then spun on the spindle and fried it to. So , Ford does have them anymore.
__________________
91 Ranger XLT SCcab 4.0L 5 Spd, 51/2" lift, Flowmaster , Winch, 33"Baja MTZ's, Belltech Shackles BC Chapter Member
I imagine Ford should still carry the parts. Wrecker should also have something. A few in Kamloops from what I remember. If you can get the numbers off the bearings it may be cheaper to get them from a bearing outfit.
__________________ Chris,#12 BS'er/Official Slackmaster #7/AVIDEST WINTER HATER BC Chapter Member/Leader JOIN THE BC CHAPTERHERE
$20 at Pick n Pull, got a door for Wifes car and a new air box top piece for $60 extra . Turns out the pass side spindle is still good but the outer nut was loose!!! And the wheel and torington bearings were both toast. Probably be $140 ish for parts and $150 - $200 for the labour.
__________________
