Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 09:59 AM
woody1333 is starting off with a positive reputation.
1985 302EFI question
Back again. Truck was idleing fine. Suddenly began pouring black smoke and idle erratic. Checked and there was gas in oil. Went through process found in forum (drained oil, replaced fuel regulator, drained oil). Started and ran decent for about 15 minutes idle and less than 2 road miles. Running rough again and oil seems to have gas. Doesn't have strong gas smell, but consistentcy. Tried pulling codes old fashioned way and the best I can determine, the codes refer to TPS.
Question is, would a bad TPS cause this problem?
  #2 (permalink)
Old 05-15-2008, 11:09 AM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
Any bad sensor will cause a problem, specifically what codes did you get?
__________________
Paul O
1990 F150 4x4 XLT Extended Cab 5.9(351 .030" over), FMS SEFI MAF Kit, Ported E6s, Crane 444232,
AOD, TransGo Shift Kit, 3:55LS, Flowtech Longtubes, TweecerRT
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08
  #3 (permalink)
Old 05-15-2008, 02:05 PM
I do not have them with me here, but I know it was related to the TPS.
Sorry I can't be more specific. I was wondering if a failing TPS could cause dumping too much fuel in the thing?
  #4 (permalink)
Old 05-15-2008, 02:51 PM
Conanski's Avatar
Yes, as stated every sensor has an impact. With fuel in the crankcase, it's more likely you have an injector stuck open or the FPR is toast and leaking fuel into the intake via the vacuum line. Definitely follow any leads the codes present to you, if the TPS has a dead spot at part throttle then the computer may think you are gone WOT and tell the injectors to open the flood gates. Anything is possible.
__________________
Paul O
  #5 (permalink)
Old 05-15-2008, 03:29 PM
IcemanV8 is starting off with a positive reputation.
Yes a bad TPS can cause you to run rich at idle and low RPM, definitely getting major fuel in the oil.
__________________
1986 Ford F-150 4x4 5.0 EFI
XLT Lariat
NP435/NP208/9" 3.50 axle
Road Warrior bumper, Leaf Spring Overloads
  #6 (permalink)
Old 05-16-2008, 09:58 AM
I drained all the oil again and am going to leave the drainplug and filter off for a day or two. I pulled all the plugs (just replaced when this started) and all looked about the same. They were each a little sooty and smelled strong of gas. None of the plugs were any wetter than the other so it does not appear to be an injector. Also there was no sign of gas in the fuel regulator line. As far as the codes go, I am not sure I have pulled the correctly, but I am pretty sure. HELP!!!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
