Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Modular V10
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 09:28 AM
triton's best's Avatar
triton's best is starting off with a positive reputation.
7" of steering play
i finally got tired of driving my truck like they did in the 60's so i changed the short end of the bar coming off my pitman arm with the balljoint, but i only lost 1" of play. i want to know where to access this little screw i have heard of on my steering box that i can adust to reduce play. any links or at least an idea of where it is would be awesome.
__________________
Maybe its the muffler bearings?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-16-2008, 11:37 PM
biz4two's Avatar
biz4two has a good reputation on FTE.biz4two has a good reputation on FTE.
Arrow
With the hood open...and looking down on the steering box...you will see a set nut and a screw. To adjust...just loosen the set nut...and turn counter clockwise. Then tighten down the set nut.
Good luck...
biz
__________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
1976 F150 LWB Custom 4x4 390FE NP435 3.50s
  #3 (permalink)
Old 05-17-2008, 04:50 AM
Monsta's Avatar
Sit. Stay. Become a
Monsta has a great reputation on FTE.Monsta has a great reputation on FTE.Monsta has a great reputation on FTE.Monsta has a great reputation on FTE.Monsta has a great reputation on FTE.
You'll need an Allen wrench to turn the screw.
__________________
Ken
05V10
So many cats, so few recipes.
  #4 (permalink)
Old 05-18-2008, 03:25 PM
thanks so much. i was so tired of swerving to keep straight if that makes any sense.
__________________
  #5 (permalink)
Old 05-20-2008, 10:35 PM
i adjusted that peice but it only made it harder to turn. i still have all of the play. im going to check other parts such as the pitman arm and other parts that turn my truck to see if there is any play.
__________________
  #6 (permalink)
Old 05-20-2008, 10:37 PM
wait one second. did i want to unscrew the allen bolt?
__________________
  #7 (permalink)
Old 05-20-2008, 11:35 PM
Monsta's Avatar
Sit. Stay. Become a
I think you want to TIGHTEN the Allen bolt a bit.
Left loosey, righty tighty.
You SHOULD rule out the other parts anyway.
__________________
Ken
05V10
  #8 (permalink)
Old 05-20-2008, 11:55 PM
i tightened the allen bolt alot. all it did was make it harder to turn the wheel. i noticed my pitman arm wasnt tightened to the point of the lock washer getting crushed flat. when i turned the wheel to observe i had noticed it shifting up and down a bit. its not so loose that the nut and lock washer arent doing their jobs but i can definitely tighten that. i dont think it will cure 7" but i never know.
__________________
  #9 (permalink)
Old 05-24-2008, 12:27 PM
69cj is starting off with a positive reputation.
There is a procedure for adjusting the steering box and if done incorrectly you will be wearing out the internal worm gear real fast. I have seen them wear to the point that the gear worms were like razor blades.
__________________
"05 F-250, CC, LB, 3.73, Lariet, with coolant filter and Bilstein shocks, S. Ca.
"69 Mustang, Mach 1, 428 CJ, Ram Air, Stock
"71 Triumph Trident
2007 Thor Jazz 5er, 11k, 31'
  #10 (permalink)
Old 05-25-2008, 11:09 AM
k. can you tell me wahat to do so i dont screw myself.
__________________
  #11 (permalink)
Old 05-25-2008, 12:58 PM
Zedrive is starting off with a positive reputation.
Siezing ball joints? [originals have no grease fittings]
Archives.
Keep smiling
__________________
Stock
99 f250 SD XLT 4X LB 6.8L 5spd. manual; Transfer hub 4.30's, LS rear 220000 km.[135000 miles]
There are two types of animals in the woods
The quick and the dead.
  #12 (permalink)
Old 06-01-2008, 10:31 AM
i give up imma get a new steering box. i get a 20% discount
__________________
  #13 (permalink)
Old 06-02-2008, 08:34 AM
krewat's Avatar
krewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud of
Wish I had seen this earlier.
WARNING WARNING WARNING - Tightening the steering box too much can make it seize up when you least expect it. It might not do it when cold, but when it gets hot, things change
7 inches of play is a lot - are you SURE it's in the steering box?
__________________
- art k. - Moderator for the Superduty, V10, and FE-series forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 eBay headers and y-pipe
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 4x4 435NP 205NP deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #14 (permalink)
Old 06-02-2008, 03:02 PM
im not sure but everything else is as solid as it can get. when i had some1 turn the wheel i could see the shaft turning with the 7 inches of play before the steering box even moved the pitman arm. i made sure i didnt tighten the steering box all of the way. i felt it go in all the way then i backed it out almost a full turn.
__________________
  #15 (permalink)
Old 06-02-2008, 05:21 PM
krewat's Avatar
Sounds like the spool valve is just completely worn out - the springs in it are probably all in "very tiny peeeeeeeeces"...
Which is why it got stiff when you tightened it - the pinion-to-whatever clearance isn't the problem. The input shaft goes through a spool valve that when you turn the wheel one way or the other, opens up hydraulic ports in the valve and push fluid one way or another inside the box. It should have a decent amount of resistance when the engine isn't running.
Do you still get 7" of sloppy play when the engines not running?
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
