Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 09:12 AM
wmiller's Avatar
wmiller is starting off with a positive reputation.
lifting and beef up suspension
My suspension is real broke down from time and plowing. I want to beef the suspension up for towing and lift it between 2-4 inches. what is the best options with out spending a pile of money? Are there any air bags that will fit with a gooseneck hitch?
__________________
97 F-250HD 7.3L 4x4 3.55 rears 232,000mi
auto meter guages, 18K mod, HPXO, 3" DP,straight piped, 6637 intake, 203# stat, myler snow plow
TS 6 position chip
http://community.wbshots.com/album/561126170UdVfeJ
  #2 (permalink)
Old 05-15-2008, 10:51 AM
tjbeggs's Avatar
Fisher of Men
tjbeggs has a very good reputation on FTE.tjbeggs has a very good reputation on FTE.tjbeggs has a very good reputation on FTE.
A dana 60 is the best option but that doesn't fit your criteria of not spending a pile of money. New front springs with an add a leaf would be the best for the front. The rear air bag will help but it will ride like a log wagon. best option would be new springs again and air bag to help when loaded. As far as fitting air bags with a goose neck I am sure it could be done with some fabrication.
__________________
Tim
Proud User of "The Cure"
For sale- 95 accelerator pedal, Gray interior and dash part, cab and more PM your request!
Click the Picture for wiring diagrams, tech info and Pictures!
  #3 (permalink)
Old 05-15-2008, 11:47 AM
wmiller's Avatar
i was figuring add spring and 350 rear block to get the height than have bags for towing. Anyone use front bags? Would this be a good option for plowing snow?
__________________
TS 6 position chip
  #4 (permalink)
Old 05-15-2008, 11:51 AM
Maxx_Mugsley is starting off with a positive reputation.
Front bags will work but you should have good springs for starters.
  #5 (permalink)
Old 05-15-2008, 12:03 PM
wmiller's Avatar
who has them? I remember seeing them before but cant remember where. All i'm comming up with is one for coil springs
__________________
TS 6 position chip
  #6 (permalink)
Old 05-15-2008, 06:35 PM
heathrunkles is starting off with a positive reputation.
someone gave me a set of ride-rite (by firestone-2320's) for the front of my truck I beleive they are rated for 3000lbs. They make a set for the rear as well, rated for 5000lbs. Not sure if they are good or not but I never do any plowing or use the front for much. i did get new springs all the way around from Kansas City Spring works online.(at least I think thats waht it was-been awhile) and it did help alot. I kept the front springs stock(big mistake as now I will be adding helper springs to the pack) The rear springs I added two leaf's for a 6800lb rating i think. It helps with towing alot but boy does she ride like a brick now.
__________________
1997 f250 HD EXT CAB LONG BED
INTERCOOLER
DIABLO 3 POSITION CHIP
K&N INTAKE
FPR SHIMMED 70#
3" DP
BANKS E4OD TRANSCOMMANDER
10K MOD
OIL TEMP MOD
HPX
1.0 A/R HOUSING
TRI-PILLAR (TRANNY, BOOST, PYRO)
  #7 (permalink)
Old 05-16-2008, 05:39 AM
WALJON is gaining momentum as a positive member of FTE.
I have air bags in the front good Idea if you plow and if you don,t want to spend a pile of money. I had my back springs re arced and added a leaf for my camper cost me $400 bucks I added a set of air bags on the back as well cost me $200 bucks.
I truly think my airbags in the front have saved my front tires.
__________________
96 F250 cab & 1/2 4x4 powerstroke
3" down pipe straight exhaust
6637 Intake mod,ccv mod
FPR shim 70 PSI thanks ROG
Glow plugs on a switch
Firestone air rite suspension
203 stat
  #8 (permalink)
Old 05-16-2008, 08:52 AM
Flea's Avatar
Flea is starting off with a positive reputation.
Hopefully this isn't a stupid question, but are there any coil spring conversions for the '97 TTB Dana 50 front axle?
__________________
Fletch
________
'97 PSD 4x4 Supercab, E40D, 3.55, 113K miles,
Waste Veg. Oil conversion - GoldenFuelSystems.com
Tymar Intake,ccv mod, 3" DP,Cat delete, muff delete, Cooner 20K mod, TruCool Max Tranny cooler.
... to come
Aeroforce Terminator gauge (Thanks Tim, I have been looking for an all in one gauge).
Truck Pics
  #9 (permalink)
Old 05-16-2008, 09:54 AM
wmiller's Avatar
i saw an air bag that says its for 250/350 with hitch is this for us or just superduties part number 2330
Amazon.com: Firestone 2330 Ford F250/350 Hitch: Automotive
__________________
TS 6 position chip
  #10 (permalink)
Old 05-17-2008, 05:40 AM
This is what you want to get
Amazon.com: Firestone 2071 Ride-Rite Kit: Automotive
__________________
203 stat
  #11 (permalink)
Old 05-17-2008, 08:51 AM
Gobstopper909's Avatar
Gobstopper909 is starting off with a positive reputation.
i just got done puttin a skyjacker add a leaf in and it leveled me right up. i lost about 3/4" with my front bushings shot too so id replace all 6 up front (2 on each spring and 1 on each shackle). . The leafs were about $165 and bushings were $30. good luck man
__________________
'97 F-250, ext cab 4x4 7.3L, Auto, CHJ shift kit, leveled up, 285's, SD HPOP, stage 1's, tymar intake, Autometer Z's, hypermax downpipe, no cat, 5" stacks, shimmed FPR, diamond cut headlights, '08 Diff cover, dixie horn, firesticks
  #12 (permalink)
Old 05-17-2008, 12:52 PM
Flea's Avatar
Where did ya get 'em? I was thinking about JC Whitney.
__________________
Fletch
________
... to come
Truck Pics
  #13 (permalink)
Old 05-17-2008, 01:44 PM
c00nhunterjoe's Avatar
c00nhunterjoe has a good reputation on FTE.c00nhunterjoe has a good reputation on FTE.
jc whitney has good deals on helper springs, last time i looked a set wa 99 bucks. and the bushings are good from lmc truck parts.
__________________
97 F-250, 4.10's Auto, Superchip, All mods by c00nhunterjoe's performance shop http://community.webshots.com/user/c00nhunterjoe
http://youtube.com/c00nhunterjoe
  #14 (permalink)
Old 05-18-2008, 01:45 PM
wmiller's Avatar
the once jc whitney has just bolt to the top of the spring pack than use u bolts the bolt to the springs right? I was told you want to stay away from this set up as it put to much strain where they bolt and can break your springs
__________________
TS 6 position chip
  #15 (permalink)
Old 05-18-2008, 02:53 PM
If you are looking for height then get new springs but if you want your suspension to ride without bagging out with a load on just get your springs re arced and put some air bags in when you are empty just let the air out and it will ride like normal they make a big dif for the snow plow too
I guess it all depends on what you want and how bad shape your suspension is
__________________
203 stat
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
