Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 08:39 AM
johnny1217 is starting off with a positive reputation.
Odometer Problem
Me again!
97 Ford explorer 6cyl.
Bought the car last week and fixed a few problems(private sale)
Yesterday I resest the tripometer and since then the that and the odometer stop working.Not going up adding miles.
I took it apart to see if maybe the cable came off but think it goes up by current.Its not digital display just plastic numbers.
I checked the fuses and all seems ok.
Is there a relay for the odometer?
I know it was working before that and how many miles i added to the truck.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-15-2008, 02:06 PM
where would the speed sensor be located on a 6cyl?
maybe thats the problem although the speedometer is working fine.
  #3 (permalink)
Old 05-15-2008, 02:43 PM
FORD PARTS GUY is starting off with a positive reputation.
Most are on the rear axel housing
  #4 (permalink)
Old 05-15-2008, 03:07 PM
gcozmo's Avatar
gcozmo is starting off with a positive reputation.
The one on my '96 used to do that sometimes. If you push the button in again and let it snap back out it should start working. I know it sounds crazy but it used to work on mine. For some reason when you push the reset in it will throw the gears out of alignment and it takes a little pursuading and patience to get it back.
__________________
Greg
'07 F150, Screw FX4, 6.5', 5.4 V8, 3.73 LS, 4x4
'04 Explorer Limited, 4.6 V8, 4X4
  #5 (permalink)
Old 05-15-2008, 04:18 PM
87 XLT is starting off with a positive reputation.
On a 97 the VSS for the speedometer & odometer is on the drivers side of
the trans. The other end of the circuit is interior fuse 25.
If the VSS was shot or the fuse was blown the speedometer would'nt work either.
FWIW the VSS in the rear diff is for the ABS nonsense only.
  #6 (permalink)
Old 05-15-2008, 04:58 PM
hmmm i looked pretty good today and couldnt find it.
Ill look again in the morning.Is it possible thats the prob?
Can't see it being much else.Other then a bad cluster.
The speedometer is working fine so not the fuse.
Thanks for the info.
  #7 (permalink)
Old 05-15-2008, 05:36 PM
The VSS is on the drivers side of the transmission tail shaft.
But, as gcosmo said, it looks like the gauge itself is the problem.
  #8 (permalink)
Old 05-16-2008, 07:32 AM
Thanks alot everyone.
since it's most prob the cluster I'm gonna take it out again later in hopes of finding something.Maybe that plastic circuit board.
I did notice last time a few bulbs blown and 2 missing.I wonder if those complete a circuit somehow.......doubt it but ill take a look.Maybe post pictures for some help.
  #9 (permalink)
Old 05-22-2008, 07:36 AM
ErnieX is starting off with a positive reputation.
Don't know if you've solved this yet but had the same problem on my 96. The speedo and odo are electronically driven by motors and gears within the speedo module of the cluster. I pulled the cluster, popped out the speedo module and you could see within the clear cover on the back that the helical gear that drives the cog gear (or vice versa) for the odo had broken in half, slipped down the shaft and no longer contacted the cog gear. Got a used cluster on Ebay for $25 (w/shipping) and swaped the speedo module and all is fine now. I saw where someone online makes and sells the replacement gears for about $35 but though the used cluster was a better solution. Also allowed me to fix my broken temp gauge.
Hope this helps.
EE
  #10 (permalink)
Old 05-22-2008, 10:16 AM
I took it all apart again and everything seemed fine to me.
All the gears seem to be ok.
I didnt take the clear plastic area off though so I may do it again and remove that area in hopes of finding something.
Unless somehow it is the sensor?
  #11 (permalink)
Old 07-04-2008, 08:06 PM
texan2004's Avatar
texan2004 is gaining momentum as a positive member of FTE.
I'd take it al the way apart (remove the plastic cover and reove the three instrument modules) to get a good lood and the little worm gear on the motor that drives the odometer. You might not be able to see the problem without removing everything. It's easy to do. The speedo needle pulls off with a little persuasion from a flat blade screw driver. See link below:
http://www.ford-trucks.com/forums/52...eter-woes.html
__________________
2003 F-250SD, 6.0 PSD
1997 Ranger XLT
1996 Explorer Sport
1950 F1
1949 F2
  #12 (permalink)
Old 07-06-2008, 06:45 PM
johnf350diesel is starting off with a positive reputation.
id do the button thing again, mine was weird like that on my '94
__________________
2004 Ford F350 FX4 Lariet 6.0 Diesel
mymudspace profile http://mymudspace.com/johnf350
  #13 (permalink)
Old 07-06-2008, 09:04 PM
texan2004's Avatar
That button trick used to work on mine but eventually stopped working. I suspect the worm gear was beginning to fail when it first acted up.
__________________
1997 Ranger XLT
1996 Explorer Sport
1950 F1
1949 F2
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
