Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Aerostar
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 08:09 AM
Absinthe is starting off with a positive reputation.
95 Aerostar Transmission (what does it mean)
When it is cold outside, and the vehicle hasn't been started all night, if I back out of the driveway, when I shift into drive it behaves like it is in neutral and after a little while (regardless of what I do so far) (perhaps 1 minute though maybe less) of just sitting it will kick into gear.
What does this suggest is wrong? If it is a warm day, or once the thing has been driven that day it doesn't do it again.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-15-2008, 09:33 AM
Sponsor
Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.
It means the bands are slipping, and do not have enough pressure to engage, most often a sign of low fluid or a leak in the valve body. Time to replace all your fluid and make sure it is at the correct level
__________________
My Rides
1994 Ford Aerostar 4.0L AWD extended
175,000 miles
Fullblown 50 series catback system
590 watt sound system
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
Custom exhaust with BearCats high flow converter and a straight through muffler
Custom high velocity intake with AFE ProDryS filter
http://www.bearriverconverters.com
  #3 (permalink)
Old 05-15-2008, 09:36 AM
Does this require flush and such?
Will they know how to do this at Jiffy Lube or do I need to take it to a real mechanic? Or is this something that I could shadetree without much trouble?
  #4 (permalink)
Old 05-15-2008, 09:39 AM
Sponsor
Definitely DO NOT have Jiffylube touch your van. Do this yourself. The flush procedure is posted as as sticky at the top of this forum. This van has all the equipment it needs to flush itself. No machine required. This method does a better job and is safer for the transmission too.
__________________
My Rides
175,000 miles
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
  #5 (permalink)
Old 05-15-2008, 12:32 PM
aerocolorado is gaining momentum as a positive member of FTE.
Bear is correct, these transmissions are sensitive to even slightly low fluid levels. Also worth mentioning, per Ford manual: parking on an incline for a prolonged period (overnight) can cause delayed engagement. Low fluid will exaggerate this situation.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
