Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Audio & Video Systems, Navigation, Satellite Radio and Mobile Electronics
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 06:06 AM
rickkk is starting off with a positive reputation.
Help stuck
Hi All,just bought an 04 F-350 S.D. and want to remove stock radio...I bought the removal tool and short of using the chainsaw I cannot get this thing out! The tool Seems to make a click on the right side but not on the left. Any Ideas? Thanks Rickkk
  #2 (permalink)
Old 05-15-2008, 09:53 AM
bgalaxy67's Avatar
bgalaxy67 is starting off with a positive reputation.
It's a pain in the rear.
The sides are spring loaded so you have to push outwards away from the deck as you pull the deck out. The tool can slide in too far making it harder to get the deck out. It takes a little practice but once you get it out the 1st time, every time after that is easy.
__________________
If the listening level is too loud, promptly inform the driver, so he may pull over, and let you out
My Excursion
Wife's 250
  #3 (permalink)
Old 05-15-2008, 08:51 PM
Truckin4life has a good reputation on FTE.Truckin4life has a good reputation on FTE.Truckin4life has a good reputation on FTE.
Be patient with it and jiggle the tool on the slide that aint clicking... its a pain like bgalaxy said... Just be patient with it... Occasionally some force is needed... Just not a whole lot...
__________________
Don
Stg's Minions: 12 volt specialist
1995 f-250 ext. cab, lb. 4x4, 5.8 5 speed. Performance mods, and a heavy foot.
Quote:
Originally Posted by STGFordCrazy04 View Post
X2 and hes not talking about truck nuts
Welcome to the Minions house.....Giving correct answers since 2007.
  #4 (permalink)
Old 05-15-2008, 09:45 PM
bgalaxy67's Avatar
All else fails.... Use a big hammer.
__________________
My Excursion
Wife's 250
  #5 (permalink)
Old 05-15-2008, 10:17 PM
no no no... its when all else fails... get a BIGGER hammer!!! lol... I dont suggest jumping straigh to a 32lb sledge though...
__________________
Don
  #6 (permalink)
Old 05-21-2008, 04:04 PM
mission completed
Thanks all,I ended up prying out the 4 WD panel and finding the left tabs were bent back too far for any
tool to move them,Icut them off!!!! that was alot of fun,It decided to come out then. Thanks again for the input. Rickk
  #7 (permalink)
Old 05-22-2008, 03:05 PM
Beerstalker's Avatar
Beerstalker has a good reputation on FTE.Beerstalker has a good reputation on FTE.Beerstalker has a good reputation on FTE.
Wow, you shouldnt have had to cut them off. You could have just pulled the whole dash panel out with the radio stuck to it. I had to do that in my 99 and it worked ok. Once the dash panel was out it was pretty easy to release the clips on the stock radio.
__________________
2007 F350 Lariat, CC, LB, 4x4
4.5" DR Lift w/35x12.5r20 Toyo Open Country M/Ts
Keystone Restyling Ram Air Hood W/Airaid Intake & Pre-filter
Recon Smoked Cab, Mirror, and Brake Lights
MSD Dashhawk w/A Pillar Mount
Dieselsite Coolant Filter
Lund Eclipse Window Vents
Weatherguard Toolbox
  #8 (permalink)
Old 05-23-2008, 04:33 AM
I guess I sometimes get too focused on things to see another way. Later Rickk
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
