Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 06:05 AM
dixiemudder04 is starting off with a positive reputation.
need some wiring help with my alt.
I just put a new altenator on and a fresh battery. I looked at daddys 351M and hooked it up just like his. I pulled the meter and it read 0.013 when i put it on the prongs on the battery. So i pulled the voltage regulator connector and took a test light and was probing around. My "I" doesnt light up when i turn the switch on. But on daddys it does. What seem to be the problem?? And y isnt my alt charging?
__________________
1978 F-150 4x4 351M, 600 Edelbrock, Aluminum Intake, 2.5" pipes with 1 chambers, 4" susp lift 3" body lift 38.5" TSL Swampers
1994 F-150 302 EFI
  #2 (permalink)
Old 05-15-2008, 10:46 AM
fmc400's Avatar
fmc400 has a good reputation on FTE.fmc400 has a good reputation on FTE.
That reading doesn't sound right at all. Are you sure you had the meter on the right scale and metric? Some meters have separate probe connections for amps and volts...I'm not trying to insult your intelligence by any means, but first I'd make sure you took that reading correctly because even on a dead battery you will still more than likely see some voltage.
  #3 (permalink)
Old 05-15-2008, 06:27 PM
Franklin2's Avatar
Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.
Does the "gen" light come on when you turn the key but not start the engine? If it doesn't, then you have a problem in that circuit. The wire comes from the ignition switch, to the "gen" light, and then to the "i" terminal. The "i" terminal is what tells the regulator to bring the alternator online to charge.
__________________
Dave F
1989 F250 XLT Diesel
  #4 (permalink)
Old 05-18-2008, 07:28 AM
So if my "I" terminal doesnt have any juice it's not telling the alt to charge? Therefore it's not going to charge the battery once the motor is running correct? So how do i fix it?
Fmc: I hooked the meter up red/red black/black. It's a fluke tester. Has three settings. And you're not insulting my intelligence. I'm not an electrician, this is all new to me. Expecially troubleshooting.
__________________
1994 F-150 302 EFI
  #5 (permalink)
Old 05-18-2008, 01:06 PM
Franklin2's Avatar
I think the 0.013 is either a typo, or you had the meter in the wrong mode. It sounds like you hooked it up correctly though. Keep messing with the meter on the battery till you get a 12v reading on the meter with the truck off. You may get 12.1, 12.5 or possibly the 0.013 was really 13 volts.
Once you get that working, leave it in that mode, and start poking around again. Probe the battery again with the engine running. The voltage should be around 14 volts if it's charging. If the voltage is the same or lower than the reading you got with the engine off, then it's not charging(you probably already know this, but lets just go through it all again).
Probe the "I" terminal again for voltage with the key on and the engine running. If you do not have voltage on the "I" terminal, I would get a short piece of wire, hook one end to the bat + and the other end to the "I" terminal. Then start the truck and measure the voltage at the battery again and see if it's charging. If it is charging, then we are definitely on the right track, and the "I" terminal wire is the problem. Now comes the hard part;
If you determine the "I" wire is the problem, the first thing I would do is pull the cluster to get at the "gen" light. If this truck has been messed with, and you have a guage instead of a "gen" light, then that's your problem. Write back in if you have a guage instead of a "gen" light, and we will have to do a little bit of wiring.
__________________
Dave F
  #6 (permalink)
Old 05-18-2008, 01:20 PM
boatmoter is starting off with a positive reputation.
check your fuse marked ignition and is your idiot light bulb any good??
Im assuming your working on a 70's truck?? it would have a external regulator then,
F -field - S - stator - I - ignition - A - battery
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
