Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 05:05 AM
OH_VDUB's Avatar
OH_VDUB is starting off with a positive reputation.
Cracks in a 460 bellhousing
Can someone help me with some advice, I have a 85-87 460 bell housing with the external slave cyinder backet. Around where the clutch fork would come out is 3 different hair line crack, what can I do get it welded or it's just junk.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-16-2008, 03:03 AM
johnboy427's Avatar
johnboy427 is starting off with a positive reputation.
If its aluminum I would try and find a new one, if its iron you should be able to get it welded just make sure you find some one who knows what they are doing you need to drill holes at the end of the crack and use the right rod, it should be stick welded. It is possible to weld cast aluminum but it is iffy at best in my opinion.
-Johnboy
__________________
-1979 F-250 4X4 400 4spd
-1989 Bronco 300six swapped in ZF 5spd
-1967 Mercury Comet Sports Coupe
  #3 (permalink)
Old 05-16-2008, 10:22 PM
mark a. is gaining momentum as a positive member of FTE.
Cast aluminum is easy to tig weld. Drilling holes at the end of a crack is just inviting porosity into a weld as far as I'm concerened, V it out and weld it up.
__________________
'79 F250 13" lift 42" Super Swampers
  #4 (permalink)
Old 05-16-2008, 10:31 PM
johnboy427's Avatar
How does drilling the ends of the cracks cause porosity? What filler would you use to TIG cast aluminum?
__________________
  #5 (permalink)
Old 05-16-2008, 10:43 PM
You have to ask ?
__________________
  #6 (permalink)
Old 05-17-2008, 12:11 AM
johnboy427's Avatar
I have never TIG welded cast aluminum so I was wandering about the filler. As for the hole causing porosity I have welded for Caterpillar for 5yrs and drilling the hole before rewelding is standard procedure and I have never had it cause porosity in all the 100s I have done. We mostly MIG but stick weld some if it requires hard/soft facing or if its just too hard to get at, has been awhile since I have TIGed anything and don't remember ever having the hole cause porosity.
-Johnboy
__________________
  #7 (permalink)
Old 05-19-2008, 01:55 AM
OH_VDUB's Avatar
Thanx for the help, the bellhousing is Aluminum. I called a local machine to get it welded, I'm dropping it off on monday to get welded but I will keep my eyes open for a different housing.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
