Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Aerostar
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 04:19 AM
theconstantevolution is starting off with a positive reputation.
awd question
ok, i been wondering, i see a lot of awd vans out there, but i havent had a chance to get close to any of them. was the awd auto only or did it come stick shift as well? wondering because i may eventually wanna convert mine, but i dont wanna lose manual trans.
  #2 (permalink)
Old 05-15-2008, 09:37 AM
Sponsor
Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.
They did not come with manual trans, but with the right adapters,you can use the Dana 28 transfer case with the manual trans. You would likely have to build such an adapter, and I'm not sure how difficult this would be.
__________________
My Rides
1994 Ford Aerostar 4.0L AWD extended
175,000 miles
Fullblown 50 series catback system
590 watt sound system
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
Custom exhaust with BearCats high flow converter and a straight through muffler
Custom high velocity intake with AFE ProDryS filter
http://www.bearriverconverters.com
  #3 (permalink)
Old 05-15-2008, 07:22 PM
xlt4wd90 is starting off with a positive reputation.
I think all the AWD vans came with the 4 liter engine, just to help move the added weight. The manual transmission vans only had the 3 liter engine. I know that the same transmission has been used on 4wd Bronco-II, but I think they had a high failure rate, as they can not handle the load. So I'm sure those poart will fit, but I don't think they will last very long.
If you wanted to add a 4wd transfer case to an Aerostar with a 5 speed manual, you're looking at starting with a 2wd with a 3 liter engine. But that's just the start; you will also need the front axle and drive shaft, and the crossmember and suspension from the 4wd vans that will allow you to install them. It would be easier to start with a 4wd van and try to adapt a stronger 5 speed manual transmission to it.
  #4 (permalink)
Old 05-16-2008, 08:24 PM
rebocardo is a name known to allrebocardo is a name known to allrebocardo is a name known to allrebocardo is a name known to allrebocardo is a name known to allrebocardo is a name known to all
Yes. I have started a conversion to a manual transfer case and once I have that done, I might go with manual hubs in the front too. I might ditch the Aerostar's whole Dana 28 and put in a Bronco II Dana 28.
__________________
The Year 2008 Anno Domini -
May it bring a great year of Revelations to you.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
