Have 1980 F150 with 85 Mustang GT 5.0 HO. rebuilt, with lightweight pistons,
shaved heads (20 th.) Crane cam 284 dur. .498 lift int & exh. ( roller ).
True roller timing, Performer products Air Gap Intake ( Chrome polished aluminum ) Dual plane. 600 CFM Edelbrock , stainless steel headers with 2.5 in. dual Flowmasters exh. with H-pipe. 9 in. posi 3.70 gears.
Truck is slow off the line then tends to pull really strong mid-range to top-end. Heard that Eddies are good up high and poor down low. Also heard that Holleys will open strong right off the line and all the way through to top-end.
Thinking about trying 600CFM Holley.
Need some input. Thanks.
Frank[/quote]
What is the rpm range on your cam? I had something along those lines in a 2 wd. My cam was 2,500 - 6,000 and i had 9" with 3.0 rear gear. Really dead off the line. I would stick with the edelbrock, unless you race this thing. What coverter do you have ? Stock ? Stall?
"Truck is slow off the line".... sounds about right for a 5.0 in a truck, and I'm not being sarcastic. The 5.0 is not known for big torque down low, and your combo definitely pushes the powerband above 3000rpm.
__________________
Paul O
1990 F150 4x4 XLT Extended Cab (Currently undergoing a heart transplant)
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08
Frank
What is the rpm range on your cam? I had something along those lines in a 2 wd. My cam was 2,500 - 6,000 and i had 9" with 3.0 rear gear. Really dead off the line. I would stick with the edelbrock, unless you race this thing. What coverter do you have ? Stock ? Stall?[/quote]
Range is 1400-5500, running stock converter , thinking about upgrading to 2500 stall. Gears are perfect , plenty of power. What about the Holley I hear
they pack a punch right off the start.
It definitely does push the powerband above 3000.RPM.
So what's your take on the Holley switch.
Its just a matter of what you like and what you are used too I have had more Holleys so I have more experince tuning them so I like them, I don't think one is better than the other I am just better at tuning holleys.
-Johnboy
__________________
-1979 F-250 4X4 400 4spd
-1989 Bronco 300six swapped in ZF 5spd
-1967 Mercury Comet Sports Coupe
