05-15-2008, 10:47 AM
Once the case is in spec, you should be good on the diff. Bearing issues are common on these, the out of round though...haven't seen that one here.
Gear noise comes up too, but could be in the set up or problems caused by the bearings.
My '98 Exploder had bearing issues, but is quiet after the fix.
If it's a problem truck, good thing you have the esp. Maybe you trade early, before the esp runs out, and eat a little on the trade, or sell it outright.
