Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 02:14 AM
pilot10 is starting off with a positive reputation.
3rd rear end replacement- solution?
So my 06 Screw, 50,700 miles is at the dealership having the rear end replaced for the 3rd time. Due last Friday. Monday I was absolutely promised Tuesday and for sure by Wednesday. When the service advisor called Tues I could tell immediately from his voice that it would be longer- needed to order a shim kit. Today he calls at 4:30 and says do you want the good news or bad news first? Apparently there is some adjusting nut or bolt on the outside of the case and the hole it fits in is rounded out so the case needs to be replaced. The advisor needs to get authorization from the ESP people to see whether they replace just the case or use a complete aftermarket unit.
? if they go with an aftermarket unit is there a a "better" & "best". I have 3.73LS now. It's also a 4x4. I'm looking for a really dependable(as in never having to do more than change fluid). I don't want to get stuck w/ some "cheap" imitation that lasts just beyond the 100k ESP warranty.
Initially I was thinking about 4.10s but then I would have to replace the front as well. This truck has had significant warranty issues(beyond the rear-end) and I don't think it is going to last(with me as owner) much longer than the loan on it- the wife already has mentioned trading it in early twice- so I don't want to spend too much on mods. But if it last 5 years it'll probably have 140k and the warranty expires at 100k.
Thanks,
Tim
__________________
06 F150 King Ranch
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-15-2008, 02:44 AM
johnboy427's Avatar
johnboy427 is starting off with a positive reputation.
Have you checked into the lemon laws you might be able to make ford buy it back if the problems are big enough.
-Johnboy
__________________
-1979 F-250 4X4 400 4spd
-1989 Bronco 300six swapped in ZF 5spd
-1967 Mercury Comet Sports Coupe
  #3 (permalink)
Old 05-15-2008, 10:47 AM
85e150six4mtod has a good reputation on FTE.85e150six4mtod has a good reputation on FTE.
Once the case is in spec, you should be good on the diff. Bearing issues are common on these, the out of round though...haven't seen that one here.
Gear noise comes up too, but could be in the set up or problems caused by the bearings.
My '98 Exploder had bearing issues, but is quiet after the fix.
If it's a problem truck, good thing you have the esp. Maybe you trade early, before the esp runs out, and eat a little on the trade, or sell it outright.
  #4 (permalink)
Old 05-16-2008, 01:33 AM
Talked w/ the service advisor- the ESP people have someone in the midwest they get complete units from. It should be here next wed, installed by Friday. Tomorrow will be 12 days in the shop.
Oh did I mention it goes into the body shop for 3-5 more days after the rear end is fixed- thanks to a Porsche 911 making an illegal left in front of me 14 days ago.
Lemon Law here is 18 months or 18k miles.
Those 09's can't come out soon enough- I think I'll try and hold out for a '10.
Tim
__________________
06 F150 King Ranch
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
